Component: Quadrature Encoder 2D (General Input)
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category General Input
Quadrature Encoder 2D component
Quadrature Encoder component implements a rotary encoder connected to two pins. Quadrature Encoders provides incremental positioning rather than absolute positioning.
Please click here to download the component source project: FC_Comp_Source_Encoder_Quadrature_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Encoder_Quadrature_2dgi.fcfx
Fc9-comp-macro.png CheckForChanges
Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error
Fc9-comp-macro.png Disable
Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call
Fc9-comp-macro.png WriteCounter32
Sets the value of the internal count variable. Range: -2147483648 to 2147483647
Fc9-s32-icon.png - LONG Value
Fc9-comp-macro.png Enable
Enables the use of the quad encoder If this is not called, the read functions will return zeros
Fc9-comp-macro.png Rotate
Simulation Rotate function to allow accurate rotation during simulation. Automatically called by any attached coupling or gearbox component.
Fc9-f32-icon.png - FLOAT Angle
Amount to rotate the shaft input in degrees
Fc9-comp-macro.png ReadCounter
Reads the current dial counter This is a counter from -32768 to 32767
Fc9-s16-icon.png - INT Return
Sets the value of the internal count variable. Range: -32768 to 32767
Fc9-s16-icon.png - INT Value
Fc9-comp-macro.png ResetCounter
Resets the current dial counter to zero
Fc9-comp-macro.png ReadCounter32
Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647
Fc9-conn-icon.png Count Variable
Fc9-type-16-icon.png Variable Type
Selects the size of the encoder count variable depending on the number of encoder counts required to be stored. The 16 bit variable counter is accessed via the ReadCounter and WriteCounter functions. The 32 bit variable counter is accessed via the ReadCounter32 and WriteCounter32 functions.
Fc9-conn-icon.png Encoder Resolution
Fc9-type-16-icon.png Post Scaler
Encoders with a mechanical click will often have 4 transitions per click. 1:1 would provide the maximum output resolution. 1:4 would provide the encoder click count.
Fc9-type-21-icon.png Edges Per Revolution
Number of signal transitions per revolution. E.g. for a 360 degree encoder you would likely get 360 x 4 = 1440 transitions and an accuracy of 0.25 degrees.
Fc9-type-15-icon.png Resolution
The resolution of the encoder in degrees
Fc9-type-5-icon.png A
Input pin A
Fc9-type-5-icon.png B
Input Pin B
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Repeat Rate
Simulated repeat rate when clicking and rotating the encoder
Fc9-type-12-icon.png Poiner Style
Fc9-type-16-icon.png Style
