Component: LCD (Grove - I2C) (Alphanumeric)
Revision as of 16:48, 30 January 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Alphanumeric
LCD (Grove - I2C) component
Standard alphanumeric LCD based on the Grove I2C LCD module with RGB backlight.
Please click here to download the component source project: FC_Comp_Source_LCD_Grove_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Grove_I2C.fcfx
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png BacklightControl
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE position
Fc9-u8-icon.png - BYTE direction
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
Fc9-comp-macro.png Start
Startup routine required by the hardware device.
Fc9-comp-macro.png SetI2CAddress
Allows the I2C device address to be dynamically changed in software without having to re-compile. Can be called before the first Start macro or at any point after.
New I2C Device Address excluding R/W bit - Range 0 - 127
Fc9-conn-icon.png I2C Config
Fc9-type-21-icon.png LCD Address
Fc9-type-21-icon.png RGB Address
Fc9-type-21-icon.png Alt RGB Address
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png LCD Configuration
Fc9-type-16-icon.png Rows
Fc9-type-16-icon.png Columns
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-1-icon.png Text Colour
Colour of the font characters drawn on the display
Fc9-type-1-icon.png Text Background
Fc9-type-1-icon.png Display Background
Used to drive the comms durig simulation which can be used to: Data Recorder waveform generation Console Logging Data Injector to redirect the data e.g. to a SCADA slave connected to the physical hardware
Fc9-type-16-icon.png API
