Component: 7Segment (Quad) 2D (Segment)
Revision as of 16:48, 30 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Segment
7Segment (Quad) 2D component
14mm seven segment display. LED colour can be set from properties.
Please click here to download the component source project: FC_Comp_Source_LED_7Seg_Quad_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_7Seg_Quad_2dgi.fcfx
ShowSegments
Allows the individual segments of the display to be controlled.
- BYTE Digit
Which of the four digits to change. (0...3)
- BYTE Segments
8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
ShowDigit
Set the number and decimal point to be displayed in the given digit of the display.
- BYTE Digit
- BYTE Value
The number value to set the digit to (0...15), 16=Clear
- BYTE DecimalPoint
Whether to show the decimal point for the chosen digit.
Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Common Type
The state of the output common pin when the 7-segment display is active. Usually a common cathode display uses a low signal and a common anode uses a high signal. If the common pin is routed via a transistor for power amplification then the signal may need to be reversed.
Show Seg Labels
Show segment name labels overlayed over the component.
Common Pin 0
Pin to enable the first digit.
Common Pin 1
Pin to enable the second digit.
Common Pin 2
Pin to enable the third digit.
Common Pin 3
Pin to enable the fourth digit.
Pin0 (A)
Pin for the 'A' segments of the displays.
Pin1 (B)
Pin for the 'B' segments of the displays.
Pin2 (C)
Pin for the 'C' segments of the displays.
Pin3 (D)
Pin for the 'D' segments of the displays.
Pin4 (E)
Pin for the 'E' segments of the displays.
Pin5 (F)
Pin for the 'F' segments of the displays.
Pin6 (G)
Pin for the 'G' segments of the displays.
Pin7 (DP)
Pin for the decimal points of the displays.
Colors
LED Color
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
Color of the plastic casing containing the LEDs.
Label Color
Color for the optional LED segment labels.
