Component: Magnetometer (SM324) (Movement Orientation)
Revision as of 16:49, 30 January 2023 by Wiki bot (talk | contribs)
Category Movement Orientation
Magnetometer (SM324) component
SM324 ultraprecise 24-bit smart magnetometer capable of distance measurement using a magnet. Controlled via I2C bus communications.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_SM324.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_SM324.fcfx
Fc9-comp-macro.png ReadStatus
Reads the status byte from the sensor IC. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation
Fc9-comp-macro.png WriteMemory
Writes a 16-bit value to the specified memory location
Internal memory address
Fc9-u16-icon.png - UINT Value
Fc9-comp-macro.png RequestData
Requests temperature and magnetic data from the device, returns status. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation
Fc9-comp-macro.png ReadTemperatureRaw
Reads the temperature from the last succesful data read.
Fc9-comp-macro.png ReadMagneticFieldRaw
Reads the magnetic field from the last succesful data read.
Fc9-comp-macro.png ReadMagneticFieldReal
Reads the magnetic field from the last succesful data read as a float in Oersted Oe.
Fc9-comp-macro.png SetAddress
Configures the device address used to communicate with sensor IC. Optionally writes the new address to the sensor IC NVM.
The new address of the sensor IC, Range 8-127
Fc9-bool-icon.png - BOOL WriteToIC
Writes the new address to the IC NVM 1=Write, 0=Don't Write
Fc9-comp-macro.png WriteCommand
Sends a command to the sensor IC.
Fc9-u8-icon.png - BYTE Command
Fc9-comp-macro.png ReadTemperatureReal
Reads the temperature from the last succesful data read as an float in degrees C.
Fc9-comp-macro.png Initialise
Sets up the I2C bus ready to communicate with the sensor IC. Sets the address variable back to the Address property value.
Fc9-conn-icon.png Sensor Properties
Fc9-type-16-icon.png Cyclic Mode
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-21-icon.png Address
Address of the SM324 IC, Default address is 16. Valid Address range = 8 to 127
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Baud rate to be used
Fc9-conn-icon.png Threshold Output
Fc9-type-5-icon.png Threshold Pin
The pins used to check the DOUT pin on the SM324,
Fc9-type-16-icon.png Threshold Setting
Controls the function of the sensor IC DOUT pin.
Fc9-type-14-icon.png Threshold1
Threshold 1 Value
Fc9-type-14-icon.png Threshold2
Threshold 2 value. If Thresh1 > Thresh2 1: Measurement > Thresh1 OR Measurement < Thresh2 0: Thresh1 > Measurement > Thresh2 If Thresh2 > Thresh1 1: Thresh1 > Measurement > Thresh2 0: Measurement > Thresh2 OR Measurement < Thresh1
Fc9-conn-icon.png Simulation
