| Author
Matrix Ltd
| Version
1.0
| Category
Segment
7Segment (Hex TM1637) 2D component
Hex seven segment display using an two pin communications bus to reduce the number of control pins. Also provides up to 16 individual input switches. Driven using a TM1637 hex 7-segment display driver.
Please click here to download the component source project: FC_Comp_Source_TM1637_7SEG_Hex_Driver_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TM1637_7SEG_Hex_Driver_2dgi.fcfx
ShowDigits
| Set the number and decimal point to be displayed in the given digit of the display.
- BYTE
Value0
| The number value to set the digit to (0...15), 16=Clear
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Value4
- BYTE
Value5
- BYTE
DecimalPoint
| Bit field containing the states of the decimal points.
ReadSwitches
| Samples the switches and returns a value from 0-16. 0 indicates that no switches are pressed. 1 - 16 indicates that a switch is pressed and provides the index of the switch. Only one switch can be pressed at any time.
- BYTE
SetBrightness
| Controls the brightness of the 7-seg displays
- BYTE
Brightness
| Range: 0-7 - 0=Darkest, 7=Brightest
- BOOL
On
| 0 = Display Off, 1 = Display On
ShowSegments
| Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
| Which of the digits to change. (0...5)
- BYTE
Segments
| The binary segment value to display
ShowDigit
| Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
| Whether to show the decimal point.
Display Type
| Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
| Show segment name labels overlayed over the component.
DIO
| Data Pin connection to TM1637 IC
CLK
| Clock Pin connection to TM1637 IC
Colors
LED Color
| Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
| Color of the plastic casing containing the LEDs.
Label Color
| Color for the optional LED segment labels.
