Component: WLAN (ESP-12S) (Comms: Networking)
Revision as of 16:50, 30 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.1
Category Comms: Networking
WLAN (ESP-12S) component
Wireless LAN component designed to work with the ESP-12S module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the BL0136 WIFI E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP12S.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP12S.fcfx
Fc9-comp-macro.png SendString
Sends the given Text with no preappendment. Useful for sending preformatted command strings. Appends a CR to the end of the string if SendCR is greater than 0.
Fc9-u8-icon.png - BYTE SendCR
Fc9-comp-macro.png DisconnectFromSSID
Disconnects from the current SSID. Returns 1 if the command was accepted and returned an "OK"
Fc9-comp-macro.png ClientConnect
Creates a TCP or UDP connection to a remote server. Returns the state of the connection. 0=Connection failed 1=Connection active
Fc9-u8-icon.png - BYTE Type
0 = TCP, 1 = UDP
Fc9-string-icon.png - STRING IPAddress
e.g. "192.168.1.20"
Fc9-u16-icon.png - UINT Port
Remote port number to connect to, HTTP comms = Port 80
Fc9-comp-macro.png ControlTCPServer
Allows a TCP web page server to be switched on and off on the selected port. Returns 1 if the command was completed correctly.
Fc9-u8-icon.png - BYTE Enable
0 = Stop Server, 1 = Start Server
Server port to listen for incoming TCP/IP data requests
Fc9-comp-macro.png GetFirmwareVersion
Collects the firmware version from the ESP8266 module and returns it as a string.
Fc9-comp-macro.png CheckForPageRequests
Fc9-comp-macro.png ClientSendRequest
Sends out a string with the required AT+CIPSEND=Length$(Request) initialiser.
Fc9-string-icon.png - STRING Request
e.g. "GET / HTTP/1.0\r\n\r\n"
Fc9-comp-macro.png ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
Fc9-u8-icon.png - BYTE Index
SSID Index
Fc9-comp-macro.png CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
Fc9-string-icon.png - STRING SSID
Name of the wireless network to create
Fc9-string-icon.png - STRING Password
Password used to gain access to the network
802.11 Channel Range 1-14
Fc9-u8-icon.png - BYTE Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
Fc9-comp-macro.png SetOutValue
Fc9-u8-icon.png - BYTE index
Range 0-4
Fc9-string-icon.png - STRING value
Fc9-comp-macro.png EndServerConnection
Disconnects from the current active TCP/IP pipe.
Fc9-comp-macro.png Send_Embedded_HTML_Page4
Fc9-comp-macro.png ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
SSID Index
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png Send_Embedded_HTML_Page3
Fc9-comp-macro.png Send_Embedded_HTML_Page2
Fc9-comp-macro.png Send_Embedded_HTML_Page1
Fc9-comp-macro.png ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
SSID Index
Fc9-comp-macro.png GetByteWithTimeout
Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available.
Fc9-comp-macro.png GetInValue
Index of the request paramter, starting at zero Range 0-2
Fc9-comp-macro.png ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
Fc9-string-icon.png - STRING Key
Fc9-u8-icon.png - BYTE Timeout
Number of seconds to wait for the connection, default 20
Fc9-comp-macro.png ClientSendArray
Sends out an array of data bytes with the required AT+CIPSEND=Length$(Request) initialiser.
Fc9-u8-icon.png - BYTE Data
Fc9-u16-icon.png - UINT NumBytes
Fc9-comp-macro.png GetRxArray
Attempts to receive a number of bytes from the remote connection If nothing is available then waits up to 200 ms for data to become available. Returns the number of bytes received,.
Byte array to store the incoming data
Fc9-u16-icon.png - UINT MaxBytes
Maximum number of bytes to try and receive
Fc9-comp-macro.png ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
Fc9-comp-macro.png Initialise
Initialise the device with the property data. Returns 1 if "ready" message successfully received Returns 0 if no reply from module
Fc9-comp-macro.png CheckTCPServerIP
Collects the local IP address of the active TCP server.
Fc9-conn-icon.png WIFI Properties
Fc9-type-21-icon.png Receive Buffer Size
Buffer used to store incoming data ready for processing. Default 128 Bytes.
Fc9-type-21-icon.png Scan Buffer Size
Buffer used to hold SSID names when performing a SSID network scan. Default 100 Bytes.
Fc9-type-16-icon.png Reset Mode
The initialise automatically resets the WIFI module before establishing communications. Software reset uses an AT command to preform the reset Hardware reset uses an extra I/O pin to toggle the signal to the reset pin on the module.
Fc9-type-16-icon.png Command Termination
Older versions of the firmware require \r to terminate a AT command string. Newer versions of the firmware have changed to use \r\n termination.
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-16-icon.png TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Fc9-type-5-icon.png Reset
WLAN module reset pin connection
Fc9-type-16-icon.png Use Flow Control
Fc9-conn-icon.png HTML Source
Fc9-type-16-icon.png Max Web Pages
Maximum number of individual webpages we can serve up with the component.
Fc9-type-21-icon.png Web Page Timeout
Number of cycles to try and send / receive a webpage before timing out.
Fc9-type-21-icon.png Line Delay
Fixed delay in microseconds sent in between sending a HTML line when running as a web page server.
Fc9-type-10-icon.png Name Page 1
HTML name of webpage 1
Fc9-type-11-icon.png HTML Page 1
HTML content for webpage 1
Fc9-type-10-icon.png Name Page 2
HTML name of webpage 2
Fc9-type-11-icon.png HTML Page 2
HTML content for webpage 2
Fc9-type-10-icon.png Name Page 3
HTML name of webpage 3
Fc9-type-11-icon.png HTML Page 3
HTML content for webpage 3
Fc9-type-10-icon.png Name Page 4
HTML name of webpage 4
Fc9-type-11-icon.png HTML Page 4
HTML content for webpage 4
Fc9-conn-icon.png Substitutions
Fc9-conn-icon.png Outgoing
Fc9-type-16-icon.png Count
Fc9-type-21-icon.png Length 0
Fc9-conn-icon.png Incoming
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png Simulation Method
Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
Decides if simulation TCP data is available via a console tab
