Component: Switch Array (Push) (Switches)
| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | Switches |
Switch Array (Push) component
An array of up to eight momentary push switches, each connected to a single pin of the specified port.
Please click here to download the component source project: FC_Comp_Source_switch_array_push.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_switch_array_push.fcfx
Here is an example Flowcode program to read the values of a switch array.
 Switch Array
Switch Array
(5V / 11K) * 10K = 4.54545V
|   | ReadState |
| Read the state of the switch at the given index. | |
|  - BYTE | Index |
| The switch to read the status of. | |
|  - BOOL | Return |
|   | WaitUntilHigh |
| Pause the program until the switch at the given index is turned on. | |
|  - BYTE | Index |
| Index of the switch to wait for. | |
|  - VOID | Return |
|   | ReadAll |
| Reads all of the switches at once, returning a byte containing one bit per switch. | |
|  - BYTE | Return |
|   | GetHandle |
| Retrieves the object handle of the switch component at the given index. | |
|  - BYTE | Index |
|  - HANDLE | Return |
|   | WaitUntilLow |
|  - BYTE | Index |
|  - VOID | Return |
