API Panel.Position.Get
Revision as of 12:31, 19 May 2013 by (username removed) (Detailed description)
<sidebar>API contents</sidebar> Gets a handle to an object representing the components current position
Class hierarchy
Panel
Position
Get
HANDLE Handle
The position or component to read from
HANDLE
Returns the handle to an object representing the components current position
Obtaining a handle to a component provides the ability to hold information about the position and coordinates of that component at the time the api is called. This has several uses for example tracking a position of an object prior to any changes to it's parameters. A good example how this is used can be seen by looking at the source code for the example provided in the API Panel.Position.Set wiki page.
  • Add to a calculation icon:
    result = ::Panel.Position.Get(handle)
