Component: Circular Buffer (16-bit) (Buffer)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.5 |
Category | Buffer |
Circular Buffer (16-bit) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific 16-bit values.
Please click here to download the component source project: FC_Comp_Source_CircularBuffer16.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CircularBuffer16.fcfx
WaitForValues
GetNumberValues
GetNumberValues |
Returns the number of valid 16-bit data values currently stored inside the buffer. | |
Return |
PeekData
PeekData |
Reads the next available 16-bit data value from the circular buffer without advancing the current index, Returns the default value if the buffer is empty. | |
Return |
PutData
LookForValues
GetData
GetData |
Reads the next available 16-bit value from the circular buffer, Returns the default value if the buffer is empty. | |
Return |
FlushBuffer
FlushBuffer |
Clears the contents of the buffer and re-initialises the index locations. | |
Return |
GetIndexedValue
GetIndexedValue |
Gets the value of a single 16-bit value at a known location in the buffer. Leaves the buffer contents and pointers untouched. | |
address |
Return |
