Component: DALI Master (Comms: System)
Revision as of 11:49, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: System
DALI Master component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND. The master component can addess up to 64 individual slaves & up to 16 groups.
Please click here to download the component source project: FC_Comp_Source_DALI_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DALI_Master.fcfx
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level. FC6 Icon.png DALI Master Example1
For a DALI Slave example see: Component: DALI Slave (Comms: System)
ReceiveBackwardFrame
Fc9-comp-macro.png ReceiveBackwardFrame
Attempts to receive an 8-bit reply 0 indicates timeout or no reply
TransmitForwardFrame
Fc9-comp-macro.png TransmitForwardFrame
Send out a 16-bit frame consisting of the 8-bit address and data bytes. After sending the controller will attempt to receive If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
Address byte
Fc9-u8-icon.png - BYTE Data
Data Byte
TransmitIndividualForwardFrame
Fc9-comp-macro.png TransmitIndividualForwardFrame
Sends out an individual frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
Individual Address 0-63
Fc9-u8-icon.png - BYTE Type
0 = Data, 1 = Command
TransmitGroupForwardFrame
Fc9-comp-macro.png TransmitGroupForwardFrame
Sends out a group frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
Group Address 0-15
Fc9-comp-macro.png Initialise
Configures the UART serial interface.
Fc9-conn-icon.png Serial Properties
Fc9-type-5-icon.png TX Pin
Fc9-type-5-icon.png RX Pin
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
