| Category | E-blocks 2 |
IO Expander component
Provides 16 digital input/output pins arranged into two 8-bit E-block 2 ports using a SPI bus connection.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_IOEXP_BL0155.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_IOEXP_BL0155.fcfx
ReadPort
|   | ReadPort |
| Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value. |
|  - BYTE | Port |
| 0=PortA, 1=PortB |
|  - BYTE | Mask |
| Allows port bits to be modified without effecting other bits, 255 = write full port. |
|  - BYTE | Return |
ConfigureInversion
|   | ConfigureInversion |
| Configures the pin inversion for the two ports.  Disabled on all pins by default. |
|  - BYTE | PortA |
| Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled |
|  - BYTE | PortB |
| Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled |
|  - VOID | Return |
ReadPortPin
|   | ReadPortPin |
| Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin. |
|  - BYTE | Port |
| 0=PortA, 1=PortB |
|  - BYTE | Pin |
| Port pin to read. Range: 0-7 |
|  - BYTE | Return |
WritePortPin
|   | WritePortPin |
| Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value. |
|  - BYTE | Port |
| 0=PortA, 1=PortB |
|  - BYTE | Pin |
|  - BYTE | Value |
| Value to output on the selected pin. Range: 0-1 |
|  - VOID | Return |
WritePort
|   | WritePort |
| Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value. |
|  - BYTE | Port |
| 0=PortA, 1=PortB |
|  - BYTE | Mask |
|  - BYTE | Value |
| Value to write. Range 0-255 |
|  - VOID | Return |
ConfigurePullups
|   | ConfigurePullups |
| Configures the pullups for the two ports. Disabled on all pins by default. |
|  - BYTE | PortA |
| Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled |
|  - BYTE | PortB |
| Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled |
|  - VOID | Return |
ReadRegister
|   | ReadRegister |
| Reads an 8-bit value from a register on the I/O expander device. |
|  - BYTE | Address |
| Register address to write to. Range: 0-15 |
|  - BYTE | Return |
WriteRegister
|   | WriteRegister |
| Writes an 8-bit value to a register on the I/O expander device. |
|  - BYTE | Address |
|  - BYTE | Value |
| Value to write. Range: 0-255 |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | SPI Communications |
|   | External Address |
| Selects the value of the three address pins for the MCP23S17. |
|   | Channel |
| SPI Channel selector |
|   | Prescale |
| Prescale option selector |
|   | MOSI |
| SPI Data Out Pin SDO - Also Known as Master Out Slave In (MOSI) when used in Master mode. |
|   | MISO |
| SPI Data In Pin SDI - Also Known as Master In Slave Out (MISO) when used in Master mode. |
|   | CLK |
| SPI Clock Pin CLK - The Clock signal is driven by the SPI master. |
|   | CS / SS |
| Chip Select / Slave Select Pin  Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device. |
|   | Reset Pin |
|   | Simulation |
|   | Label |
|   | Show Comms Flasher |
|   | Scope Traces |
| Selects if the scope traces are automatically generated or not |
|   | Console Data |
| Selects if the console data is automatically generated or not |
|   | API |
