Component: GLCD (EB075) (E-blocks 1)
Revision as of 11:49, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
GLCD (EB075) component
Graphical display component designed to work with the Goldelox range of displays from 4D Systems. Also available in the form of the EB075 GLCD E-block.
Please click here to download the component source project: FC_Comp_Source_GLCD_4D_EB075.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_4D_EB075.fcfx
EB075 gLCD Example File EB075 Example Example should show the following on the display on the panel and on the hardware.
G4D_InitialiseCard
G4D_InitialiseCard
Initialises the micro SD card inserted into the module is available. Returns 0 for succesful initialisation or 255 for a detected failure. Does not currently simulate.
- INT Number
- UINT X
- UINT Y
- BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE Transparent
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
Plot
- UINT X1
- UINT Y1
FastPlot
FastPlot
G4D_DisplayVideoFromCard
Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
- UINT X
- UINT Y
- UINT AddH
- UINT AddL
BPlot
BPlot
- UINT X1
- UINT Y1
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
G4D_ReadJoystickGoldelox
Reads the value of the joystick input. 0 = No press detected / 1 = Up Pressed / 2 = Left Pressed / 3 = Down Pressed / 4 = Right Pressed / 5 = Fire Pressed
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
G4D_DisplayImageFromCard
Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
- UINT X
- UINT Y
- UINT AddH
Byte Address High Word
- UINT AddL
Byte Address Low Word
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
TX
RX
Reset Pin
Reset pin connection
Baud Options
Component Label
Component Label Scale
Physical Orientation
Console Columns
Data Source
