Component: GLCD (SSD1306) I2C (SSD1306) (Graphical Monochrome)
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.9
Category Graphical Monochrome
GLCD (SSD1306) I2C component
Graphical display component based on the I2C version of the SSD1306 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1306_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1306_I2C.fcfx
ReadFontWidth
Fc9-u8-icon.png - BYTE Font
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SendCommand
Fc9-comp-macro.png SendCommand
Fc9-u8-icon.png - BYTE Command
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawEllipse
Fc9-u8-icon.png - BYTE Solid
Plot
Fc9-comp-macro.png Plot
ControlDisplay
Fc9-comp-macro.png ControlDisplay
Allows the display to be switched on and off
Fc9-u8-icon.png - BYTE Control
0=Off, 1=On
SetDisplayOrientation
BPlot
Fc9-comp-macro.png BPlot
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
ControlContrast
Fc9-comp-macro.png ControlContrast
Sets the display contrast from 0 to 255.
Fc9-u8-icon.png - BYTE Contrast
Range 0 - 255, Default 207
ClearDisplay
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
DrawCircle
Fc9-comp-macro.png DrawCircle
SetForegroundColour
0=White, 1=Black
DrawRectangle
Fc9-comp-macro.png Initialise
InvertDisplay
Fc9-comp-macro.png InvertDisplay
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Interlaced
Fc9-type-21-icon.png Offset X
Fc9-type-21-icon.png Offset Y
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png I2C Address
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Physical Orientation
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
