Author
Matrix Ltd
Version
1.5
Category
Graphical Monochrome
GLCD (ST7565R) Parallel component
Graphical display component designed to work with the ST7565 type monochrome displays. Transfers data using an 8-bit digital data bus.
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7565R.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7565R.fcfx
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
SetForegroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pins
Decides if the 8-bit data bus is controlled using a full port or individual pins. A full port will run faster whereas individual pins allow for more flexibility.
DATAPORT
CS1
Chip select pin
RES
Reset pin
A0
RD_E
Enable pin used to clock data into the display
WR_RW
Read Write pin to set the display data mode
MODE
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
