Component: Keypad (4x4) (Keypad)
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Category Keypad
Keypad component
Preset keypad based around the 4 * 4 unit.
Please click here to download the component source project: FC_Comp_Source_Keypad_4x4.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Keypad_4x4.fcfx
WaitPressed
Fc9-comp-macro.png WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
GetAscii
Fc9-comp-macro.png GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetString
Fc9-comp-macro.png GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns the value 255.
GetNumber
Fc9-comp-macro.png GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetIndex
Fc9-comp-macro.png GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
WaitReleased
Fc9-comp-macro.png WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Fc9-type-16-icon.png Output Mode
Fc9-type-19-icon.png Port
Fc9-conn-icon.png Appearance
Fc9-type-1-icon.png Backplate Colour
Fc9-conn-icon.png Button 1
Fc9-type-1-icon.png Key colour
Set the colour of the key body here. This is applied to all objects making up a key, including the background colour of any text labels.
Fc9-type-1-icon.png Label colour
Set the colour for the default 'ASCII' text label on the key-cap. This setting will be ignored if a bitmap is set for the key label.
Fc9-conn-icon.png Button 2
Fc9-conn-icon.png Button 3
Fc9-conn-icon.png Button 4
Fc9-conn-icon.png Button 5
Fc9-conn-icon.png Button 6
Fc9-type-2-icon.png Label colour
Fc9-conn-icon.png Button 7
Fc9-conn-icon.png Button 8
Fc9-conn-icon.png Button 9
Fc9-conn-icon.png Button 10
Fc9-conn-icon.png Button 11
Fc9-conn-icon.png Button 12
Fc9-conn-icon.png Button 13
Fc9-conn-icon.png Button 14
Fc9-conn-icon.png Button 15
Fc9-conn-icon.png Button 16
