Component: Magnetometer 3-Axis (HMC5883L) (Movement Orientation)
Revision as of 11:51, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Movement Orientation
Magnetometer 3-Axis (HMC5883L) component
HMC5883L 3-Axis Magnetometer sensor Useful for working out data such as compass orientation.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_HMC5883.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_HMC5883.fcfx
Here is a very simple demonstration on how to use the sensor to read X, Y, Z magnetometer data from the sensor.
FC6 Icon.png HMC5883L Demo
Read_Register
Fc9-comp-macro.png Read_Register
Reads a value from a register on the accelerometer.
Fc9-u8-icon.png - BYTE Reg
Write_Register
Fc9-comp-macro.png Write_Register
Writes a data value to a specific register on the accelerometer
Fc9-u8-icon.png - BYTE Data
UpdateCompassData
Fc9-comp-macro.png UpdateCompassData
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
CollectXYZData
Fc9-comp-macro.png CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
Fc9-u8-icon.png - BYTE Axis
Fc9-s16-icon.png - INT Return
SimSetCompass
Fc9-comp-macro.png SimSetCompass
Allows the XYZ slider values to be set via the simulation
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Read_Bearing
Fc9-comp-macro.png Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
Fc9-u8-icon.png - BYTE NumSamples
The number of readings to base the bearing on
Fc9-comp-macro.png Initialise
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
Fc9-type-16-icon.png Measurement Mode
Continuous mode makes constant sensor readings setting the RDY pin when new data is available. Single mode does a single sensor read setting the RDY pin when done and then waits for data to be read.
Fc9-type-16-icon.png Num Samples
The number of samples that are averaged together to provide the readings.
Fc9-type-16-icon.png Compass Data Rate
Sets the output conversion rate.
Fc9-type-16-icon.png Compass Scale
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-7-icon.png Use RDY Pin
Fc9-conn-icon.png Simulation
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - Injector etc
