Component: OBD2 ECU (Server) (Misc)
Jump to navigationJump to search| Author | |
| Category | Misc |
- 1 OBD2 ECU (Server) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Set_VIN
- 5.2 Set_Engine_Speed
- 5.3 Set_Engine_Coolant_Temperature
- 5.4 Process
- 5.5 DTC_Clear
- 5.6 DTC_Get
- 5.7 DTC_Count
- 5.8 Set_ECU_Name
- 5.9 GetNumberBytes
- 5.10 Set_Vehicle_Speed
- 5.11 Set_MAF_Rate
- 5.12 Set_Engine_Load
- 5.13 DTC_Add
- 5.14 GetByte
- 5.15 Set_Throttle_Position
- 5.16 FlushBuffer
- 5.17 Initialise
- 6 Property reference
Implements an ECU side OBD-II server
Please click here to download the component source project: FC_Comp_Source_OBD2_ECU.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OBD2_ECU.fcfx
Set_VIN
|   | Set_VIN |
| Set the 17 character VIN | |
|  - STRING | VIN |
|  - VOID | Return |
Set_Engine_Speed
|   | Set_Engine_Speed |
| 0 to 16,383.75 (rpm) | |
|  - FLOAT | Value |
| Speed in RPM | |
|  - VOID | Return |
|   | Set_Engine_Coolant_Temperature |
| -40 to 215 (deg C) | |
|  - FLOAT | Value |
| Value range -40 to 215 deg C | |
|  - VOID | Return |
Process
|   | Process |
| Does the message processing. Call this often. | |
|  - UINT | TimeElapsed |
| Time elapsed since last call, in mS. Can be zero for frequent calling. | |
|  - BYTE | Return |
DTC_Clear
|   | DTC_Clear |
| Clears the DTC store | |
|  - VOID | Return |
DTC_Get
|   | DTC_Get |
| Get the DTC from the store at Index | |
|  - UINT | Index |
|  - STRING | Return |
DTC_Count
|   | DTC_Count |
| Returns the number of stored DTCs | |
|  - UINT | Return |
Set_ECU_Name
|   | Set_ECU_Name |
| Set the ECU Name | |
|  - STRING | Name |
|  - VOID | Return |
GetNumberBytes
|   | GetNumberBytes |
| Returns the number of valid data bytes currently inside the buffer. | |
|  - UINT | Return |
Set_Vehicle_Speed
|   | Set_Vehicle_Speed |
| 0 - 255 (km/h) | |
|  - FLOAT | Value |
| Speed in RPM | |
|  - VOID | Return |
Set_MAF_Rate
|   | Set_MAF_Rate |
| 0 to 655.35 grams/sec | |
|  - FLOAT | Value |
| MAF air flow rate in grams/sec | |
|  - VOID | Return |
Set_Engine_Load
|   | Set_Engine_Load |
| 0 to 100 (%) | |
|  - FLOAT | Value |
| Speed in RPM | |
|  - VOID | Return |
DTC_Add
GetByte
|   | GetByte |
| Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty. | |
|  - UINT | Return |
|   | Set_Throttle_Position |
| 0 - 100 (%) | |
|  - FLOAT | Value |
| Position value as a percentage (0 - 100%) | |
|  - VOID | Return |
FlushBuffer
|   | FlushBuffer |
| Clears the contents of the buffer and re-initialises the index locations. | |
|  - VOID | Return |
|   | Initialise |
| Initialise the CAN network | |
|  - BYTE | Return |
