Component: PicoScope (PS2000) (Test Equipment)
Jump to navigationJump to search| Author | Matrix Ltd |
| Category | Test Equipment |
- 1 PicoScope component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ps2000_get_timebase
- 5.2 ps2000_open_unit_progress
- 5.3 ps2000_flash_led
- 5.4 ps2000_stop
- 5.5 ps2000_get_unit_info
- 5.6 ps2000_set_channel
- 5.7 ps2000_get_times_and_values
- 5.8 ps2000_set_trigger
- 5.9 ps2000_set_sig_gen_built_in
- 5.10 ps2000_close_unit
- 5.11 ps2000_run_block
- 5.12 ps2000_get_values
- 5.13 ps2000_ready
- 5.14 ps2000_open_unit_async
- 5.15 ps2000_open_unit
- 6 Property reference
PicoScope component
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
Please click here to download the component source project: FC_Comp_Source_PS2000.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_PS2000.fcsx
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
ps2000_get_timebase
| ps2000_open_unit_progress | |
| This function checks on the progress of a request made to ps2000aOpenUnitAsync to open a scope. | |
| handle | |
| Progress | |
ps2000_flash_led
| ps2000_flash_led | |
| This function flashes the LED on the front of the scope without blocking the calling thread. | |
| handle | |
| handle of the scope device | |
ps2000_stop
| ps2000_stop | |
| This function stops the scope device from sampling data. If this function is called before a trigger event occurs, the oscilloscope may not contain valid data. | |
| Handle | |
ps2000_set_channel
| ps2000_get_times_and_values | |
| Handle | |
| times | |
| buffer_a | |
| buffer_b | |
| buffer_c | |
| buffer_d | |
| overflow | |
| time_units | |
| no_of_samples | |
ps2000_set_trigger
| ps2000_set_trigger | |
| handle | |
| source | |
| threshold | |
| direction | |
| delay | |
| auto_trigger_ms | |
ps2000_close_unit
| ps2000_close_unit | |
| This function shuts down an oscilloscope. | |
| Handle | |
| The handle of the scope device to be closed | |
ps2000_run_block
| ps2000_run_block | |
| This function starts collecting data in block mode. | |
| handle | |
| no_of_samples | |
| timebase | |
| oversample | |
| time_indisposed_ms | |
ps2000_get_values
ps2000_ready
| ps2000_ready | |
| Handle | |
| ps2000_open_unit_async | |
| This function opens a scope without blocking the calling thread. | |
ps2000_open_unit
| ps2000_open_unit | |
| Returns a handle to the opened unit Returns 0 if no unit found Returns -1 if unit failed to open | |
| Properties |
