| Author
Matrix TSL
| Version
1.0
| Category
File
WAV Player ROM component
Stores an audio WAV file in ROM and contains component macros to allow the WAV file to be streamed out. Compatible with analogue outputs such as DAC or PWM.
Please click here to download the component source project: FC_Comp_Source_WAV_Player.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WAV_Player.fcfx
SetFilePointer
SetFilePointer
| Allows direct control of the file pointer. Write the file pointer to 0 to reset the pointer to the beginning of the file. Write the file pointer to 0xFFFFFFFF to force the pointer to the end of the file.
- ULONG
Pointer
| Range: 0x0 to 0xFFFFFFFF, 0 = Beginning of file
EndOfFile
EndOfFile
| A simple check to see if we are at the end of the file. Returns 0 if we and not yet at the end fo the file. Returns 1 if we are at the end of the file.
- BOOL
GetNumChannels
GetNumChannels
| Returns the number of audio channels stored in the WAV file.
- BYTE
GetBitsPerSample
GetBitsPerSample
| Returns the number of bits per sample.
- BYTE
GetNextSample
GetNextSample
| Retreives the value for the next sample and auto increments the file pointer. Ideally this function should be called as part of a timer interrupt at the sample rate. The value returned should be passed onto a means of analogue output e.g. a DAC or PWM.
- UINT
WAV File
| WAV File to Embed into the ROM Flash memory.
File Status
| Displays diagnostic data about the selected file.
Num Channels
| Number of audio channels encoded in the WAV file. 1 indicates a MONO audio stream. 2 indicates a STEREO autio stream.
Sample Rate
| The rate in samples per second at which the WAV file was recorded.
Bits Per Sample
| The number of bits used to store a single sample.
Byte Rate
| The number of data bytes per second that need to be processed in order to maintain playback.
ROM Bytes
| Number of bytes of ROM that will be required to store the WAV file.
