Component: WLAN (ESP32) (Comms: Networking)
Revision as of 11:53, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.4
Category Comms: Networking
WLAN (ESP32) component
Wireless LAN component designed to work with ESP32 modules
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32.fcfx
ReadIPString
ReadIPString
Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1"
- STRING Return
SocketConnect
SocketConnect
- STRING Address
- UINT Port
SocketListen
SocketListen
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
- UINT Port
ReadSSIDFromScan
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE Index
SSID Index
- STRING Return
CreateAccessPoint
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING SSID
Name of the wireless network to create
- STRING Password
Password used to gain access to the network
- BYTE Channel
802.11 Channel Range 1-14
- BYTE Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
ReadIP
ReadIP
Collects a single byte from the local IP address. For example 192.168.0.1 Index = 3 : Return = 192 / Index = 0 : Return = 1
- BYTE Index
Range: 0 to 3 Where 3 = the first number and 0 = the last number
SocketWrite
SocketWrite
- STRING Buffer
- UINT Size
Disconnect
Disconnect
Attempts to disconnect from the SSID.
ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE Index
SSID Index
- INT Return
ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE Index
SSID Index
ConnectToSSID
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING SSID
- STRING Key
- BYTE Timeout
Number of seconds to wait for the connection, default 20
SocketOpen
SocketOpen
Returns 1 if socket sucessfully opened
SocketClose
SocketClose
Uninitialise
Uninitialise
Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not
AcceptOpen
AcceptOpen
Returns 1 if there is an incoming connection on the listening port
ScanForSSID
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
SocketRead
SocketRead
- STRING Buffer
- UINT Size
AcceptClose
AcceptClose
Close the socket associated with the Accepted incoming connection
Initialise the WiFi system Returns 1 if successful Returns 0 if not
Verbose Debug
Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
Generate Console Data
