Component: Marking control (Misc)
| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Misc |
Marking control component
A control to draw markings on any component
Please click here to download the component source project: FC_Comp_Source_markings.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_markings.fcfx
DrawStripY
| DrawStripY | |
| Draw the marks on the readout Set up the position and range with SetRange() and SetSpan() | |
| OffsetX | |
| Offset to add to X | |
SetTarget
| SetTarget | |
| Sets the target image to draw on | |
| Target | |
| AreaX | |
| The X area to draw on | |
| AreaY | |
| The Y area to draw on | |
| AutoCreate | |
| Set true to auto-create the graphic | |
DrawStripX
| DrawStripX | |
| OffsetY | |
| Offset to add to Y | |
BoundRange
| BoundRange | |
| Bounds a range to be between RangeStart and RangeEnd | |
| Range | |
| The unbounded range | |
DrawArc
| DrawArc | |
| Draw the marks on the readout Set up the position and range with SetRange() and SetArc() | |
| Radius | |
| Scale of the radius to draw at | |
SetAngles
| SetAngles | |
| Sets the min-max angles to draw on the dial Used for setting the needle Defaults are 135 and -45 | |
| Start | |
| End | |
SetShow
| SetShow | |
| Decides on the presentation of the dial | |
| ShowNumbers | |
| True to show numbers on the dial, else false | |
| ShowMarks | |
| Show marks | |
CalcScaleRange
| CalcScaleRange | |
| Decide the range value for a 0->1 value Returned value may be out of range | |
| ScaledRange | |
CalcAngRange
| CalcAngRange | |
| Decide the range value for an angle Returned value may be out of range | |
| AngleDegrees | |
CalcScale
| CalcScale | |
| Decide the scale (0->1) to display at given a range value | |
| RangeVal | |
SetMarks
| SetMarks | |
| Marks | |
| Number of marks on the dial | |
| Subs | |
| Number of marks before a 'main' mark - can be zero | |
ClearArea
| ClearArea | |
| Clears the draw area | |
SetRange
| SetRange | |
| Sets the min-max range to draw on the dial Used for setting the needle | |
| Start | |
| End | |
SetGaps
| SetGaps | |
| Sets the min-max of the span to draw on the X/Y marks Defaults are 0 and 1 | |
| Start | |
| End | |
SetJustify
| SetJustify | |
| RAlign | |
| True for right/top/outer alignment | |
CalcAngle
| CalcAngle | |
| Decide the angle to display at given a range value | |
| RangeVal | |
| Properties |
