Component: API (Arduino Mega) (API Slave Devices)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API (Arduino Mega) component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_temp/Arduino_Mega_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Arduino_Mega_API_Comp.fcfx
ADCSample10
Fc9-comp-macro.png ADCSample10
Reads the voltage present on an Analog pin as an 10-bit value range 0-1023
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0-15
ADCSample8
Fc9-comp-macro.png ADCSample8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255
Range: 0-15
ADCSampleArray10
Fc9-comp-macro.png ADCSampleArray10
Range: 0-5
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
ADCSampleArray8
Fc9-comp-macro.png ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
Range: 0-5
Range: 1- 32
Fc9-u8-icon.png - BYTE Samples
8-bit samples returned from the function
ADCSampleAverage10
Fc9-comp-macro.png ADCSampleAverage10
Range: 0-5
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
ADCSampleAverage8
Fc9-comp-macro.png ADCSampleAverage8
Range: 0-5
Range: 1- 100
ADCSetPrechargeTime
Fc9-comp-macro.png ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
Fc9-u8-icon.png - BYTE ChargeTime
Default 10
ADCSetReferenceVoltage
Fc9-comp-macro.png ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
Fc9-u8-icon.png - BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
I2CInitialise
Fc9-comp-macro.png I2CInitialise
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
I2CRestart
Fc9-comp-macro.png I2CRestart
I2CSend
Fc9-comp-macro.png I2CSend
I2CStart
Fc9-comp-macro.png I2CStart
I2CStop
Fc9-comp-macro.png I2CStop
I2CTransInit
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
I2CTransReceive
Fc9-comp-macro.png I2CTransReceive
Data variable to receive into
Fc9-u16-icon.png - UINT Count
Number of bytes to receive
I2CTransSend
Fc9-comp-macro.png I2CTransSend
Data to send
IOGetInputPin
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-53
IOSetOutputPin
Fc9-comp-macro.png IOSetOutputPin
Range: 0-53
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png Initialise
PWMDisable
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-15
PWMEnable
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-15
PWMSetDuty
Fc9-comp-macro.png PWMSetDuty
Range: 0-15
Fc9-u8-icon.png - BYTE Duty
PWMSetPrescaler
Fc9-comp-macro.png PWMSetPrescaler
Range: 0-15
Fc9-u8-icon.png - BYTE Period
Default 255
RegisterRead
Fc9-comp-macro.png RegisterRead
Read one of the registers on-board the device
Fc9-u16-icon.png - UINT RegisterAddress
The address of the register
RegisterWrite
Fc9-comp-macro.png RegisterWrite
Writes to one of the registers on-board the device
The data value to assign to the register
SPIInitialise
Fc9-comp-macro.png SPIInitialise
SPIPrescaler
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
SPITransfer
Fc9-comp-macro.png SPITransfer
SPITransferTrans
Fc9-comp-macro.png SPITransferTrans
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
UARTBaud
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
UARTCheckRX
Fc9-comp-macro.png UARTCheckRX
UARTInitialise
Fc9-comp-macro.png UARTInitialise
UARTReceive
UARTSend
Fc9-comp-macro.png UARTSend
Fc9-conn-icon.png Connection
Fc9-type-16-icon.png COM Port
Lists all the current available COM port hardware on your PC.
Fc9-type-7-icon.png Refresh Ports
Fc9-conn-icon.png API Peripherals
Fc9-type-21-icon.png Digital IO
Fc9-type-21-icon.png Analog Input
Fc9-type-21-icon.png Analog Output
Fc9-type-21-icon.png PWM Output
Fc9-type-21-icon.png I2C Bus
Fc9-type-21-icon.png SPI Bus
Fc9-type-21-icon.png UART
Fc9-type-21-icon.png Servo
Fc9-conn-icon.png Console
Fc9-type-7-icon.png Console Log
Create an automatic console log of the commands sent to the Arduino
Fc9-type-16-icon.png Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
