Component: Rx/Tx Flasher (Advanced Shapes)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Advanced Shapes
Rx/Tx Flasher component
Simple indicator panel intended as a sub-component of communications components. The two arrow shapes can be set to flash by the host component to represent incoming and outgoing data packets. The panel can be labelled and use a custom icon for easy identification. The icon area can be set to open a pre-defined console window when clicked. LEDs can also be flashed by sending the component a User Notify event. Event 'Message ID' is ignored. Data should be: 1, to flash to Rx LED or 2 to flash the Tx LED.
Please click here to download the component source project: FC_Comp_Source_temp/Comms_indicators.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Comms_indicators.fcfx
FlashRx
Fc9-comp-macro.png FlashRx
Lights the Rx LED - the arrow on the left of the component. It will turn off again automatically when the time set by the Flash Time property has expired. Intended to be called when a comm's component has received a packet of data.
FlashTx
Fc9-comp-macro.png FlashTx
Lights the Tx LED - the arrow on the right of the component. It will turn off again automatically when the time set by the Flash Time property has expired. Intended to be called when a comm's component has sent a packet of data.
SetConsole
Fc9-comp-macro.png SetConsole
Register the handle of a console window. This console will be opened when the icon on the component is clicked (the area between the two arrows).
Fc9-h32-icon.png - HANDLE Handle
Handle of the console to call up.
Fc9-type-10-icon.png Label
Text for the label at the top of the component.
Fc9-type-13-icon.png Icon
Path to a bitmap image to be displayed in the icon area between the two arrows. The image will be resized to fit the area - it should ideally be a square image, and must be less than 128 pixels along each side. To ensure that the icon displays reliably, it should be stored as one of the host component's resources.
Fc9-type-14-icon.png Flash Time (ms)
How long each LED should remain lit following a trigger event.
Fc9-conn-icon.png Colors
Fc9-type-1-icon.png Tx On
LED colour when the transmit LED (right) is lit.
Fc9-type-1-icon.png Tx Off
LED colour when the transmit LED (right) is unlit
Fc9-type-1-icon.png Rx On
LED colour when the receive LED (left) is lit.
Fc9-type-1-icon.png Rx Off
LED colour when the receive LED (left) is unlit.
