Component: On/Off Control (DSP Operators)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
On/Off Control component
On/Off Control - Standard on off control as used on most ovens, toasters, irons.
Please click here to download the component source project: FC_Comp_Source_temp/DSP_OnOffControl.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DSP_OnOffControl.fcfx
Here is a project file showing an on off control system for a system such as an electric oven.
The setpoint is set via an analogue input which controls the desired temperature of the system.
In this first example the feedback is provided using the simulated load DSP component which simply takes a percentage of the last output and combines with a percentage of the new output.
This allows easy moddeling of systems such as ovens that heat up and cool down over time which allows you to see the system in action.
You assign a setpoint and then the system will get to temperature and then maintain the output by automatically switching the output on and off.
When the feedback is less then the setpoint minus the hysteresis then the output is switched on.
When the feedback is more then the setpoint then the output is switched off.
On Off Control Simulated Output Example
In this second example the feedback is provided via a temperature sensor component. This shows how you would do it with a real system using a sensor to complete the feedback loop.
On Off Control Example
As with other DSP components the raw signals and values can be seen in the data recorder and console windows.
Process
Process
Processes the current value from a buffer.
ProcessArray
ProcessArray
Processes an entire buffer, either by performing the control operation to every value in the buffer or just the last value.
Setpoint Connect To
Feedback Connect To
Buffer Size
Buffer Type
Sets the buffer data type.
Control
Hysteresis
Minimum variation before the output will be allowed to switch state. Used to avoid high frequency oscillation on the control output.
On Value
Value passed to the output buffer when the control output is active or on.
Off Value
Value passed to the output buffer when the control output is not active or off.
