Component: Rectifier (DSP Operators)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Rectifier component
Converts the negative elements of a signal into a mirrored positive signal.
Please click here to download the component source project: FC_Comp_Source_temp/DSP_Rectifier.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DSP_Rectifier.fcfx
ControlRectifier
Fc9-comp-macro.png ControlRectifier
Enables or disables the rectifier, enabled by default
Fc9-bool-icon.png - BOOL State
0=Disable, 1=Enable
Rectify
Fc9-comp-macro.png Rectify
Collects a single value from the input buffer and outputs a rectified version of the value.
RectifyArray
Fc9-comp-macro.png RectifyArray
Passes an entire buffer through the rectifier and outputs a rectified version of the buffer at the other end
Fc9-type-16-icon.png Connect To
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-type-16-icon.png Direction
Sets the data direction flow of the component
Fc9-conn-icon.png Rectifier
Fc9-type-14-icon.png Rectifier Threshold
Value at which to choose to flip the signal. Default 0 for a signed buffer.
