Component: EBM0016 GUI (Misc)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix
Category Misc
EBM0016_GUI component
Private non-release sub-component for the EBM0016 digital Humidity/temperature sensor.
Please click here to download the component source project: FC_Comp_Source_temp/EBM0016_GUI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBM0016_GUI.fcfx
GetData
Fc9-comp-macro.png GetData
Return a simulated register value for the given commands. Recognised commands are 0xF3 (Temperature register) and 0xF5 (Humidity Register). Note that a CRC checksum is not used in simulation.
Fc9-u8-icon.png - BYTE Command
The address of the byte to return.
SetConsoleHandle
Fc9-comp-macro.png SetConsoleHandle
Pass the parent sensor's console handle to the GUI to allow opening of the console from the 'Console' button.
Fc9-h32-icon.png - HANDLE Handle
Handle of the console
SetHumidity
Fc9-comp-macro.png SetHumidity
Sends the given Humidity to the display, and calculates the internal values used by the simulated read macros.
Fc9-f32-icon.png - FLOAT Humidity
Relative Humidity from 0 to 100 %
SetTemperature
Fc9-comp-macro.png SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
Fc9-f32-icon.png - FLOAT Temperature
Temperature value in Celcius,
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
A text label to help you identify the component on the panel.
Fc9-type-10-icon.png Sub Label
Fc9-type-15-icon.png Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Fc9-type-15-icon.png Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Fc9-type-21-icon.png Scale divisions
Number of numbered divisions shown on the thermometer scale.
Fc9-type-16-icon.png I2C Data
Choose whether the I2C data is shown as decimal or hexadecimal values.
