Component: Humidity (EBM016) (EBM Modules)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category EBM Modules
Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the Matrix e-block module EBM016. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_temp/EBM016v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBM016v1.fcfx
This example reads the temperature and humidity levels from the sensor and displays the readings on the LCD.
EBM016 Example
GetHumidityData
GetHumidityData
Returns the raw register pair value
GetHumidityInt
GetHumidityInt
returns the relative Humidity reading as an integer value
- INT Return
GetHumidityReal
GetHumidityReal
returns the Humidity reading as a float value
- FLOAT Return
GetTemperatureData
GetTemperatureData
GetTemperatureInt
GetTemperatureInt
Return temperature reading as an integer value in degrees C
- INT Return
GetTemperatureReal
GetTemperatureReal
Return temperature reading as a float value in degrees C
- FLOAT Return
Initialises the component ready for I2C communications
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulation Comms
