Component: Ultrasonic (EBM019) (EBM Modules)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Category EBM Modules
Ultrasonic component
This board has both an ultrasonic transmitter and receiver. The transmitter is driven by an on-board 40KHz oscillator which is enabled by the host microprocessor. The receiving sensor signal is amplified and provided as an analogue signal to be processed by a single channel ADC of the microprocessor. By measuring the time delay between enabling a transmit pulse and receiving an echo the distance of objects in a range of around 3cm to 3m can be determined.
Please click here to download the component source project: FC_Comp_Source_temp/EBM019v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBM019v1.fcfx
Sample program using the EBM019 - Ultrasonic sensor.
Sends out a pulse and determines distance from time taken to receive reflection.
FC6 Icon.png EBM019 Example
GetDistance
Fc9-comp-macro.png GetDistance
Sends a pulse and processes the echo. Returns a object distance in cm
Fc9-comp-macro.png Initialise
Setup the device. This sets the control output to logic 0
SetDelayTime
Fc9-comp-macro.png SetDelayTime
Set the delay time before sampling for the echo, in microseconds
Fc9-u16-icon.png - UINT delay
delay time in microseconds
SetDetectionValue
Fc9-comp-macro.png SetDetectionValue
Set the delta value for echo detection
Fc9-u8-icon.png - BYTE value
trigger point for echo detection
SetPulseWidth
Fc9-comp-macro.png SetPulseWidth
Set the output pulse width, in microsecond (0-255uS)
Fc9-u8-icon.png - BYTE pulse
width of pulse in microseconds
Fc9-type-5-icon.png Output Pulse Pin
Pin used for controlling the output pulse
Fc9-type-6-icon.png Echo ADC channel
ADC channel used to monitor the echo
Fc9-type-21-icon.png Pulse Width (uS)
Output ultrasonic pulse width in microseconds
Fc9-type-21-icon.png Read Delay (uS)
Time delay in microseconds before sampling for echo
Fc9-type-21-icon.png Pulse Detection Value
Detection ADC delta trigger value A lower value is more sensitive
