Component: Flash EEPROM (EEPROM)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Category EEPROM
Flash EEPROM component
Provides an emulated version of EEPROM using the microcontrollers on-board flash program memory. Requires a microcontroller with write and erase access to the flash memory.
Please click here to download the component source project: FC_Comp_Source_temp/FlashEE.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/FlashEE.fcfx
Read
Read
Reads a single value from the Flash EEPROM at the specified address
- UINT Address
- ULONG Return
Write
Write
Writes a single value to the Flash EEPROM at the specified address
- UINT Address
- ULONG Data
Enabled
Is the Flash EEPROM component currently supported on the selected MCU device?
Number Of Values
Number of individual values that can be read and written using the component. The more values you want the bigger the RAM buffer required to store the data when performing a write.
Flash Page
Flash Page to use as EEPROM
Flash Address
Initialiser
Bits Per Value
Number of bits available when initialising the Flash memory.
Bits Per Instruction
Number of bits that can be stored or retreived using a single flash address
