Component: Temp / Humidity (HTS221) (Environmental)
Version | 1.0 |
Category | Environmental |
Temp / Humidity (HTS221) component
A temperature and relative humidity sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 3.5% Temperature Range = -40 - 120 Degrees C +/- 0.5 Degrees C
Please click here to download the component source project: FC_Comp_Source_temp/Humidity_HTS221.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Humidity_HTS221.fcfx
ControlHeater
DataAvailable
Initialise |
Configures the I2C peripheral ready for communications. | |
Return |
ReadHumidityInt
ReadHumidityInt |
Samples the humidity from the sensor and returns the relative humidity reading as a integer byte from 0 to 100 | |
Return |
ReadHumidityReal
ReadHumidityReal |
Samples the humidity from the sensor and returns the relative humidity reading as a float from 0.0 to 100.0. | |
Return |
ReadRegister
ReadRegister |
Reads an 8-bit value from one of the registers onboard the sensor IC. | |
Address |
Return |
ReadTemperatureInt
ReadTemperatureInt |
Samples the temperature from the sensor and returns the reading in degrees C as an integer from -40 to 120. | |
Return |
ReadTemperatureReal
ReadTemperatureReal |
Samples the temperature from the sensor and returns the reading in degrees C as a float from -40.0 to 120.0. | |
Return |
WriteRegister
WriteRegister |
Writes a value to a register on the sensor IC. | |
Address |
Data |
Return |
