Component: IoT Made Easy (Comms: IoT/Cloud)
Version | 1.0 |
Category | Comms: IoT/Cloud |
IoT Made Easy component
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
Please click here to download the component source project: FC_Comp_Source_temp/IoTMadeEasy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/IoTMadeEasy.fcfx
Connect
Connect |
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected. | |
Return |
Disconnect
Disconnect |
Disconnects from the MQTT server and the network | |
Return |
ErrorAsString
ErrorAsString |
Error |
Return |
GetPayloadFloat
GetPayloadFloat |
Get the Payload of the last received (Read) packet as a floating point value | |
Return |
GetPayloadInteger
GetPayloadInteger |
Get the Payload of the last received (Read) packet as a signed long value | |
Return |
GetPayloadString
GetPayloadString |
Get the Payload of the last received (Read) packet as a string value | |
Payload |
Size |
Return |
GetTopicID
GetTopicID |
Compares the topic ID of the last received message with enabled IDs. Returns the topic ID received. | |
Return |
Initialise |
Starts up the MQTT component - call this after initialising the NetworkComms component. | |
Return |
LastError
LastError |
Returns the last error | |
Return |
Ping
PublishFloat
PublishInteger
PublishString
Read
Read |
Read incoming data. Returns non-zero if packet received. Use GetTopicID and GetPayloadXXX to read the contents. | |
Return |
