Component: Keypad (Cursor 3x3) (Keypad)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Category Keypad
Keypad (Cursor 3x3) component
A preset keypad component with up, down, left and right cursors, and a selection of function keys, in a 3 by 3 matrix. Return values (Index or Number) are... 0 = F1, 1 = Up, 2 = F3 3 = left, 4 = OK, 5 = right 6 = F2, 7 = down, 8 = F4. 255 = No key pressed.
Please click here to download the component source project: FC_Comp_Source_temp/Keypad_Cursor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Keypad_Cursor.fcfx
GetAscii
Fc9-comp-macro.png GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetIndex
Fc9-comp-macro.png GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
GetNumber
Fc9-comp-macro.png GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetString
Fc9-comp-macro.png GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string.
WaitPressed
Fc9-comp-macro.png WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
WaitReleased
Fc9-comp-macro.png WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Fc9-conn-icon.png Dimensions
Fc9-type-16-icon.png Keys
Number of columns (left to right) in the array of keys. Must be a value from one to four.
Fc9-conn-icon.png Return Values
Fc9-type-10-icon.png ASCII
A list of return values for the 'GetString' and 'GetASCII' macros. Enter a string with one character per key, in order of key scanning. Columns are counted first (left-to-right), then rows (direction set by the 'First Row' property) e.g. for a 2*2 grid, the order would be... [Row0, Column0], [Row0,Column1], ][Row1, Column0], [Row1, Column1]
Fc9-type-11-icon.png Numbers
A list of return values for the 'GetNumber' macro. Enter a comma separated list with one integer value per key, in order of key scanning. Columns are counted first (left-to-right), then rows (direction set by the 'First Row' property) e.g. for a 2*2 grid, the order would be... [Row0, Column0], [Row0,Column1], ][Row1, Column0], [Row1, Column1]
Fc9-type-16-icon.png Output Mode
Fc9-type-19-icon.png Port
Fc9-conn-icon.png Appearance
Fc9-type-1-icon.png Backplate Colour
Fc9-conn-icon.png Button 1
Fc9-type-1-icon.png Key colour
Set the colour of the key body here. This is applied to all objects making up a key, including the background colour of any text labels.
Fc9-type-1-icon.png Label colour
Set the colour for the default 'ASCII' text label on the key-cap. This setting will be ignored if a bitmap is set for the key label.
Fc9-conn-icon.png Button 2
Fc9-type-1-icon.png Up arrow colour
Fc9-conn-icon.png Button 3
Fc9-conn-icon.png Button 4
Fc9-type-1-icon.png Left arrow colour
Fc9-conn-icon.png Button 5
Fc9-conn-icon.png Button 6
Fc9-type-2-icon.png Right arrow colour
Fc9-conn-icon.png Button 7
Fc9-conn-icon.png Button 8
Fc9-type-2-icon.png Down arrow colour
Fc9-conn-icon.png Button 9
