Component: LCD I2C (Backpack) (Alphanumeric)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.2
Category Alphanumeric
LCD I2C (Backpack) component
Standard alphanumeric LCD based on a standard I2C control bus. Usually using either a PIC device or Microchip IO expander IC.
Please click here to download the component source project: FC_Comp_Source_temp/LCD_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LCD_I2C.fcfx
A simple example that shows how to use some common functions.
Backpack LCD Example
If the display is not showing the expected characters, the I2c address or contrast could be wrong.
It's best to keep the jumper connected since the backlight is enabled by default.
Using an Arduino Uno the correct I2C address can be determined by using an IC2 Address Sniffer
The I2C address to use is the one within the first set of square brackets.
For example, with my backpack display, the correct address to use is 0x3F [63]:
The other two Addresses i.e. 0x56 [86] and 0x68 [104] is for my 24C32 EEPROM and DS3231 RTC respectively.
Note The I2c addresses scan will repeat every 5seconds.
The sniffer will send data to your PC via UART to USB.
The Arduino range and clones will have it built-in.
More details on I2C can be found here,
BacklightControl
BacklightControl
- BYTE State
Clear
Clear
ClearLine
ClearLine
- BYTE Line
Command
Command
- BYTE instruction
Cursor
Cursor
- BYTE x
- BYTE y
PrintAscii
PrintAscii
- BYTE character
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
PrintString
PrintString
- STRING Text
RAMWrite
RAMWrite
- BYTE Index
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
ScrollDisplay
ScrollDisplay
- BYTE position
- BYTE direction
SetI2CAddress
SetI2CAddress
Allows the I2C device address to be dynamically changed in software without having to re-compile. Can be called before the first Start macro or at any point after.
- BYTE Address
New I2C Device Address excluding R/W bit - Range 0 - 127
Start
Start
Startup routine required by the hardware device.
I2C Config
LCD Address
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
LCD Configuration
Rows
Columns
Use Backlight
Controls if the backlight is controlled as part of the main data routine or if it is handled separately.
Component Label
Component Label Scale
Text Colour
Text Background
Colour surrounding the font characters drawn on the display
Display Background
Colour of the background of the display
Simulate Comms
Allows the communications to be simulated via an injector component.
