Component: LED Matrix (Serial) (LEDs)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category LEDs
LED Matrix (Serial) component
LED Matrix component designed to work using a single data and clock pin. Each LED on the display can be controlled in a chain by setting the data appropriatley and then generating the appropriate amount of clock pulses.
Please click here to download the component source project: FC_Comp_Source_temp/LED_Matrix.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Matrix.fcfx
ClearLEDs
Fc9-comp-macro.png ClearLEDs
Sets all of the LEDs in the matrix to the off state.
DisplayString
Fc9-comp-macro.png DisplayString
Prints an ASCII string onto the LED Matrix a column at a time.
Data string to display on the LEDs
Fc9-u16-icon.png - UINT Animation_Delay
Delay in milliseconds between writing to the next column
Fc9-u8-icon.png - BYTE Leadout
Allows the text to scroll completely off the display before returning 0=No, 1=Yes
Fc9-u8-icon.png - BYTE Add_Spaces
Add spaces between each ASCII character 0=No, 1=Yes
StrobeHigh
Fc9-comp-macro.png StrobeHigh
Sets the strobe pin high. Strobing controls the LED brightness and does not apply to simulation.
StrobeLow
Fc9-comp-macro.png StrobeLow
Sets the strobe pin low. Strobing controls the LED brightness and does not apply to simulation.
WriteColumn
Fc9-comp-macro.png WriteColumn
Allows a single column of data to be inserted, Acts to shift the rest of the columns across by one.
Fc9-u8-icon.png - BYTE Data
Data to display on the column of LEDs
Fc9-type-16-icon.png LED Type
Active high outputs a logic 1 to set the LED and logic 0 to clear the LED. Active low outputs a logic 0 to set the LED and logic 1 to clear the LED
Fc9-type-14-icon.png Row Count
Number of LED rows
Fc9-type-14-icon.png Column Count
Number of LED columns
Fc9-type-14-icon.png LED Count
Total number of LEDs in the component
Fc9-type-7-icon.png Flip Display
Allows the column and text data sent to the display to be flipped
Fc9-type-5-icon.png Data In
Data In pin which is used to pass the input LED value
Fc9-type-5-icon.png Data Out
Data Out Pin - Optional and used to collect the data as it leaves the last buffer
Fc9-type-5-icon.png Clock
Clock pin used to clock the external buffer IC's
Fc9-type-5-icon.png Strobe
Strobe pin used to control the master display state, strobed at high speed using PWM to set the brightness.
Fc9-type-5-icon.png Reset
Reset pin used to clear all of the states in the external buffer IC's
Fc9-conn-icon.png Colours
Fc9-type-1-icon.png On Color
Simulated colour of the LEDs when switched On
Fc9-type-1-icon.png Off Color
Simulated colour of the LEDs when switched Off
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Row Spacing
Simulation row spacing
Fc9-type-15-icon.png Column Spacing
Simulation column spacing
Fc9-type-15-icon.png Width
Simulation LED width
Fc9-type-15-icon.png Height
Simulated LED height
Fc9-type-15-icon.png Depth
Simulated LED Depth (3D environments only)
Fc9-type-16-icon.png LED Shape
Simulated LED basic shape
Fc9-type-7-icon.png Redraw LEDs
Simulated LED redraw option, display will not be updated until the redraw is set to Yes. Automatically revers back to No after the refresh has been performed.
