Component: MIAC (PIC) (Misc)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.7
Category Misc
MIAC (PIC) component
MIAC - Matrix Industrial Automotive Controller PLC type module based on a PIC18F4455 device, produced by Matrix Component includes functions to drive the functionality of the MIAC and MIAC system.
Please click here to download the component source project: FC_Comp_Source_temp/MIAC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MIAC.fcfx
Analogue Input
Basic example of how to read an analogue input on the MIAC and display it on the LCD. FC6 Icon.png MIAC ADC LCD
Keypad Input
Basic example of how to read the keypad and display the value on the LCD. FC6 Icon.png MIAC Keypad For reference the numbering of the MIAC keypad looks like this.
Output Control
Basic example of how to control all of the individual outputs on the MIAC using the keypad.
Note that for the transistor outputs to come on you must wire a connection from the +V terminal to the M terminal.
If you are driving high current outputs then you can instead supply separate DC power to the M terminal. FC6 Icon.png MIAC Outputs MIACOuts.jpg
MIAC Interrupt Controlled Clock
Basic example of how to create a timer interrupt based clock. FC6 Icon.png MIAC Clock MIACclock.jpg
DisplayClear
Fc9-comp-macro.png DisplayClear
Clears the display to white space
DisplayCommand
Fc9-comp-macro.png DisplayCommand
Sends the given command to the display
Fc9-u8-icon.png - BYTE Cmd
DisplayCursor
Fc9-comp-macro.png DisplayCursor
Moves the display cursor to the given position. If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
Fc9-u8-icon.png - BYTE x
Position of the cursor in characters from left to right.
Fc9-u8-icon.png - BYTE y
The line to move the cursor to.
DisplayStart
Fc9-comp-macro.png DisplayStart
Initialise the display ready for use
GetKeypad
Fc9-comp-macro.png GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
InputANALOG
Fc9-comp-macro.png InputANALOG
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
Fc9-u8-icon.png - BYTE InputID
The input to read from 1 to 8.
InputANALOG_10Bit
Fc9-comp-macro.png InputANALOG_10Bit
Returns the 10 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
Fc9-s16-icon.png - INT Return
InputDIGITAL
Fc9-comp-macro.png InputDIGITAL
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8)
The input number from 1 to 8.
OutputOFF
Fc9-comp-macro.png OutputOFF
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4)
Fc9-u8-icon.png - BYTE TransID
1 to 4 (Outputs A to D)
OutputON
Fc9-comp-macro.png OutputON
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4)
PrintASCII
Fc9-comp-macro.png PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
Fc9-u8-icon.png - BYTE Char
ASCII code of the character to print.
PrintFormattedNumber
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Prints the given number to the display starting at the current cursor position and moves the cursor position.
Fc9-s16-icon.png - INT n
PrintString
Fc9-comp-macro.png PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
The string to send to the display.
RelayOFF
Fc9-comp-macro.png RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
Fc9-u8-icon.png - BYTE RelayID
The relay to turn off. From 1 to 4.
RelayON
Fc9-comp-macro.png RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
The relay to turn on from 1 to 4.
