Component: One Wire (DS2482) (Comms: Interface)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: Interface
One Wire (DS2482) component
A One Wire master transciever controlled using I2C comms. Useful for microcontroller devices where One Wire communications timings are too tight to do reliably.
Please click here to download the component source project: FC_Comp_Source_temp/One_Wire_DS2482_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/One_Wire_DS2482_I2C.fcfx
BusReset
Fc9-comp-macro.png BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
GetDeviceCount
Fc9-comp-macro.png GetDeviceCount
GetIDByte
Fc9-comp-macro.png GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
Fc9-u8-icon.png - BYTE Device
Device ID - Range: 0 - NumDevices - 1
Fc9-u8-icon.png - BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
Fc9-comp-macro.png Initialise
MatchROM
Fc9-comp-macro.png MatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
Fc9-u8-icon.png - BYTE FamilyCode
Fc9-u8-icon.png - BYTE SerialNumber
ReceiveByte
Fc9-comp-macro.png ReceiveByte
ScanBus
Fc9-comp-macro.png ScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
SkipROM
Fc9-comp-macro.png SkipROM
Performs a bus reset and the sends the SkipROM command byte
TransmitByte
Fc9-comp-macro.png TransmitByte
Transmit a byte to the one wire bus a bit at a time
Fc9-u8-icon.png - BYTE Command
Fc9-type-21-icon.png Max Devices
Controls the maximum number of devices that can be detected during a ScanBus. For each additional device we require 8 bytes to store the ROM ID. Default: 8 = 64 Bytes of RAM
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Device Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Options
Baud rate to be used
Fc9-conn-icon.png Simulation
