Component: Photo Reflector (Light)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Category Light
Photo Reflector component
Uses InfraRed light to detect if an external object is near to the sensor. Returns a discrete analogue signal which can represent distance from the nearest object. Useful for applications like wall following, control based systems and robotics.
Please click here to download the component source project: FC_Comp_Source_temp/PhotoReflector.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/PhotoReflector.fcfx
Fc9-comp-macro.png Initialise
Sets up the I/O to allow the sensor to operate.
SampleSensor
Fc9-comp-macro.png SampleSensor
Samples the sensor and automatically controls the emitter pin if enabled. Returns the analogue reading from the sensor pin.
Fc9-type-16-icon.png Emitter Type
Decides if the emitter needs to be switched on and off during sampling
Fc9-type-6-icon.png Sense Pin
Pin connected to the sensor element of the photo transistor
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Discrete Distance
Simulation range used to determine if the sense pin is active or not.
