Component: TCP/IP (Raspberry Pi) (Comms: Networking)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.9
Category Comms: Networking
TCP/IP (Raspberry Pi) component
TCP/IP sockets component for use with Raspberry Pi. Raspberry Pi Only
Please click here to download the component source project: FC_Comp_Source_temp/TCPIP_RPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/TCPIP_RPI.fcfx
AcceptClose
Fc9-comp-macro.png AcceptClose
Close the accept socket
AcceptOpen
Fc9-comp-macro.png AcceptOpen
Connect
Fc9-comp-macro.png Connect
Attempt to connect to the given address and port. First open a socket on the local device using the Socket function and check that it is successful.
Fc9-string-icon.png - STRING Address
Remote destination address
Fc9-u16-icon.png - UINT Port
Remote destination port
Fc9-comp-macro.png Initialise
Initialises the TCP/IP component
Listen
Fc9-comp-macro.png Listen
Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful.
Receive
Fc9-comp-macro.png Receive
Receive data into the data buffer. Returns the number of bytes received
Data byte buffer to receive the data
Fc9-u16-icon.png - UINT Count
Maximum number of bytes to read
Send
Fc9-comp-macro.png Send
Send data
Data byte buffer to send
Number of bytes to send
SocketClose
Fc9-comp-macro.png SocketClose
Close the socket
SocketOpen
Fc9-comp-macro.png SocketOpen
Attempts to create a socket on the local device. Type =0 for TCP, =1 for UDP This must be successfully done before attempting connection with a remote destination. Returns 1 if successful, 0 if not.
Fc9-u8-icon.png - BYTE Type
Type of socket to create
Fc9-type-10-icon.png Label
