Component: TCP/IP Dummy (Raspberry Pi) (Comms: Networking)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.8
Category Comms: Networking
TCP/IP Dummy component
TCP/IP sockets component for use with Raspberry Pi. Raspberry Pi Only
Please click here to download the component source project: FC_Comp_Source_temp/TCPIP_RPI_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/TCPIP_RPI_Dummy.fcfx
Here is an example of using the TCP/IP component as a means to request data from a remote server on the internet or local network.
Example RPI Client Request Data
Here is an example of using the TCP/IP component as a means to serve data to a client via the internet or local network.
Example RPI HTML Webserver
AcceptClose
AcceptClose
Close the accept socket
AcceptOpen
AcceptOpen
Connect
Connect
Attempt to connect to the given address and port. First open a socket on the local device using the Socket function and check that it is successful.
- STRING Address
Remote destination address
- UINT Port
Remote destination port
Listen
Listen
Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful.
- UINT Port
Receive
Receive
Receive data into the data buffer. Returns the number of bytes received
- STRING Data
Data byte buffer to receive the data
- UINT Count
Maximum number of bytes to read
Send
Send
Send data
- STRING Data
Data byte buffer to send
- UINT Count
Number of bytes to send
SocketClose
SocketClose
Close the socket
SocketOpen
SocketOpen
Attempts to create a socket on the local device. Type =0 for TCP, =1 for UDP This must be successfully done before attempting connection with a remote destination. Returns 1 if successful, 0 if not.
- BYTE Type
Type of socket to create
