Component: DALI Slave (Comms: System)
Jump to navigationJump to search| Author | MatrixTSL |
| Category | Comms: System |
DALI Slave component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND using external circuitry.
Please click here to download the component source project: FC_Comp_Source_temp/DALI_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DALI_Slave.fcfx
CheckForGroupAddress
| CheckForGroupAddress | |
| Tests the 16-bit incoming data for the defined group address Returns 0 for no match, returns 1 for a match | |
| Data | |
CheckForIndividualAddress
| CheckForIndividualAddress | |
| Tests the 16-bit incoming data for the defined individual address Returns 0 for no match, returns 1 for a match | |
| Data | |
CollectDataByte
| CollectDataByte | |
| Returns the data byte from a 16-bit data packet | |
| Data | |
CollectPacketType
| CollectPacketType | |
| Returns if the incoming packet was data or a command. Return of 0 = Data Return of 1 = Command | |
| Data | |
| Configures the UART serial interface. | |
ReceiveForwardFrame
| ReceiveForwardFrame | |
| Attempts to receive an 16-bit command from the master controller. 0xFFFF indicates timeout or no reply | |
TransmitBackwardFrame
| TransmitBackwardFrame | |
| Send out a 8-bit frame consisting of a data byte. | |
| Data | |
| Data Byte | |
| Properties | |
| Serial Properties | |
| TX Pin | |
| RX Pin | |
| DALI Slave Properties | |
| Individual Address | |
| Address ranging from 0-63 | |
| Group Address | |
| Address ranging from 0-15 | |
| Simulation | |
| API | |
