Component: Temp / Humidity (DHT22) (Environmental)
Version | 1.2 |
Category | Environmental |
Temp / Humidity (DHT22) component
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 2% Temperature Range = -40 - 80 Degrees C +/- 0.5 Degrees C
Please click here to download the component source project: FC_Comp_Source_temp/DHT22.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DHT22.fcfx
Example Program showing how to sample the DHT22 sensor and show the temperature and humidity on an LCD.
DHT22 Example
GetHumidityFloat
GetHumidityFloat |
Gets the humidity returned by calling SampleSensor as a floating point number. If humidity is 15.8 % then this function would return 15.8. | |
Return |
GetHumidityReal
GetHumidityReal |
Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8. | |
Return |
GetHumidityString
GetHumidityString |
Gets the humidity returned by calling SampleSensor as a string. If humidity is 15.8 % then this function would return "15.8". | |
Return |
GetHumidityWhole
GetHumidityWhole |
Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15. | |
Return |
GetTempFloat
GetTempFloat |
Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8. | |
Return |
GetTempReal
GetTempReal |
Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8. | |
Return |
GetTempString
GetTempString |
Gets the temperature returned by calling SampleSensor as a string. If temperature is 15.8 degrees C then this function would return "15.8". | |
Return |
GetTempWhole
GetTempWhole |
Gets the whole number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 15. | |
Return |
SampleSensor
SampleSensor |
Communicates with the DHT22 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error. | |
Return |
