Component: DMX-512 Master (Comms: System)
Revision as of 12:18, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 2.0
Category Comms: System
DMX-512 Master component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
Please click here to download the component source project: FC_Comp_Source_temp/DMX-512_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DMX-512_Master.fcfx
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet.
DMX Master Example1
For DMX 512 slave example see: DMX Slave
Configures the UART serial interface.
SendDataChain
SendDataChain
Transmits the BREAK, MAB and StartCode followed by the contents of the data channels.
- BYTE StartCode
SetDataChannel
SetDataChannel
Sets the data byte in a data channel
- UINT Channel
- BYTE DataValue
Serial Properties
Baud Options
TX
DMX Properties
Data Channels
Number of data bytes used by the DMX chain, Max 512 bytes per transmission. 24 Bytes minimum to match minimum 1204us timing requirements, not all channels need to be used.
Console Columns
Data Source
