Component: Output DAC (DSP Outputs)
Revision as of 12:18, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Outputs
Output DAC component
Allows the values from a buffer to be passed directly to an internal DAC output.
Please click here to download the component source project: FC_Comp_Source_temp/DSP_DAC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DSP_DAC.fcfx
ControlDAC
Fc9-comp-macro.png ControlDAC
Enable or disable the DAC output, Disabled by default.
Fc9-bool-icon.png - BOOL State
OutputDAC
Fc9-comp-macro.png OutputDAC
Outputs a single value from the input buffer appropriatley scaled to suit the DAC.
OutputDACArray
Fc9-comp-macro.png OutputDACArray
Outputs an array of values from the input buffer appropriatley scaled to suit the DAC.
Fc9-u16-icon.png - UINT Delay
Delay in microseconds between outputting each sample.
Fc9-type-16-icon.png Connect To
Fc9-type-16-icon.png Channel
DAC Channel number
Fc9-type-5-icon.png DAC Output Pin
DAC Output Pin
Fc9-conn-icon.png DAC
Fc9-type-7-icon.png Auto Adjust Scale
Yes: Automatically convert samples to match the full bit depth of the DAC. No: Leave the samples at the native bit depth.
Fc9-type-16-icon.png Vref Option
Fc9-type-15-icon.png Vref Voltage
Fc9-type-14-icon.png Control Bits
Fc9-type-10-icon.png Resolution
Fc9-type-15-icon.png Voltage Resolution
Fc9-type-21-icon.png Bit Depth
Max number of bits for each DAC sample.
