| Author
Matrix TSL
| Version
1.0
| Category
E-blocks 2
GLCD Monochrome component
Graphical display component designed to work with the EB2 BL0139 Downstream E-block.
Please click here to download the component source project: FC_Comp_Source_temp/EBlocks2_Mono_GLCD_BL0139.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBlocks2_Mono_GLCD_BL0139.fcfx
BPlot
BPlot
- BYTE
X1
- BYTE
Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
DrawRectangle
DrawRectangle
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
Transparent
- BYTE
Solid
Goto_XY
Goto_XY
- BYTE
X
- BYTE
Y
Plot
Plot
- BYTE
X1
- BYTE
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
| Specifies the colour of the foreground
- BYTE
PixelColour
| 0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
| Specifies the colour of the foreground.
- BYTE
PixelColour
| 0=White, 1=Black
Write_Command
Write_Command
- BYTE
Command
Write_Data
Write_Data
- BYTE
data
Version
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
| Number of bits of colour depth available on the display
Red Bit Depth
| Number of bits of Red colour depth on the display
Green Bit Depth
| Number of bits of Green colour depth on the display
Blue Bit Depth
| Number of bits of Blue colour depth on the display
CS
| Chip select pin
Reset
A0
| Address pin to tell the display if we are sending commands or data
Data Pin
Clock Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Display Method
Component Label
Component Label Scale
