Component: Injector (API Digital Output) (Test Injectors)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Test Injectors
Injector (API Digital Output) component
Data injector to allow a physical digital output pin to be attached to a simulated component. The component will forward any output state changes through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
Please click here to download the component source project: FC_Comp_Source_temp/InjectorSCADADigitalOutput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/InjectorSCADADigitalOutput.fcfx
GetConsoleHandle
GetConsoleHandle
- HANDLE Return
InitialiseInjector
InitialiseInjector
- STRING InjectorName
RxByte
RxByte
RxByteCount
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
TxByte
TxByte
- BYTE DataByte
API Slave
Number of Pins
Specifies the number of pins the component can monitor and control.
Pin 0
Simulation I/O Pin
Pin monitored by the simulation
SCADA Slave Pin
Pin used by the connected SCADA Slave hardware
