| Author
Matrix Ltd
| Version
2.0
| Category
LEDs
LED Matrix component
LED Matrix component designed to work using a HT16K33 LED driver IC. Can drive up to 16 x 8 (128) LEDs. Includes support for 8x16 Backpack, 16x8 Featherwing, 8x8 Backpack and Custom.
Please click here to download the component source project: FC_Comp_Source_temp/LED_Matrix_HT16K33.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Matrix_HT16K33.fcfx
Example to display a bitmap image on the LED matrix using the Bitmap Drawer component.
File:HT16K33 Bitmap.zip
ClearLEDs
ClearLEDs
| Sets all of the LEDs in the matrix to the off state.
DisplayString
DisplayString
| Prints an ASCII string onto the LED Matrix a column at a time.
- STRING
Data
| Data string to display on the LEDs
- UINT
Animation_Delay
| Delay in milliseconds between writing to the next column
- BYTE
Leadout
| Allows the text to scroll completely off the display before returning 0=No, 1=Yes
- BYTE
Add_Spaces
| Add spaces between each ASCII character 0=No, 1=Yes
- BYTE
Orientation
| 0=Normal, 1=Rotated 90 Degrees
| Configures the I2C peripheral and sets up the HT16K33 IC ready to drive the LEDs.
SetBrightness
SetBrightness
| Configures the brightness of the LEDs by varying the On portion of the duty.
- BYTE
Brightness
| Range: 0-15 - 0 = Min Brightness, 15 = Full Brightness
ShiftColumns
ShiftColumns
| Shifts the columns one place left or right. Used for things like displaying scrolling text.
- BYTE
Direction
| 0 = Shift Left, 1 = Shift Right
WriteColumn
WriteColumn
| Allows a single column of 8 LEDs to be controlled in a single action.
- BYTE
Column
| Range: 0-15
- BYTE
Data
| Data to display on the column of LEDs
WriteCommand
WriteCommand
| Writes a command.
- BYTE
Command
WriteLED
WriteLED
| Allows a single LED to be controlled using the basic column / row coordinate system. Each column is comprised of 8 rows.
- BYTE
Column
| Range: 0-15
- BYTE
Row
| Range: 0-7
- BYTE
Data
| 0 = LED Off, 1 = LED On
WriteLEDXY
WriteLEDXY
| Allows a single LED to be controlled using a more standard X, Y coordinate system. 0,0 refers to the bottom left hand LED. Only works with the fixed display modules, custom module not supported.
- BYTE
X
| X coordinate. Range: 0-15
- BYTE
Y
| Y coordinate. Range: 0-15
- BYTE
State
| State 0=Off, 1=On
WriteRegister
WriteRegister
| Writes a value to a register.
- BYTE
Address
- BYTE
Value
Display Module
| Selects the layout of the module you are controlling. Several modules are available in pre wired formats to provide an off the shelf LED matrix.
LED Count
| Total number of LEDs in the component
Slave Address
| Sets the software device slave address. Must be configured to match the wiring of the three hardware address pins.
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Colours
On Color
| Simulated colour of the LEDs when switched On
Off Color
| Simulated colour of the LEDs when switched Off
PCB Colour
Label Colour
Simulation Type
| Sets the simulation type. Component GUI allows the object on the panel to reflect what the reakl life LED matrix should do. I2C Injector allows the I2C communications to be simulated via injectors.
GUI
Column Spacing
| Simulation column spacing
Width
| Simulation LED width
Row Spacing
| Simulation row spacing
Height
| Simulated LED height
Depth
| Simulated LED Depth (3D environments only)
LED Shape
| Simulated LED basic shape
