| Author
Ben Rowland 2014
| Version
1.0
| Category
Misc Circuit
LED Cube component
LED Cube component for driving 3D arrays of LEDs. A typical cube could consist of 4x4x4 or 8x8x8 but does not necessarily need to be a cuboid.
Please click here to download the component source project: FC_Comp_Source_temp/LEDCUBE.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LEDCUBE.fcfx
Clear
Clear
| Clears the contents of the display to 0x0000
- BYTE
SwitchBuffers
| 0=DoNotSwitch 1=SwitchAutomaticallyWhenDone
ConvColourToRGB
ConvColourToRGB
| Reads the individual RGB colour values from a single UINT colour value. Return Index: 0=Red, 1=Green, 2=Blue
- UINT
Colour
- STRING
ConvRGBToColour
ConvRGBToColour
| Converts RGB values into a single UINT colour parameter to use with other functions.
- BYTE
Red
- BYTE
Green
- BYTE
Blue
- UINT
DisplayCharacter
DisplayCharacter
| This macro allows a character to be displayed on the screen
- BYTE
Character
- BYTE
X1
- BYTE
Y1
- BYTE
Z1
- BYTE
Font
| Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE
Axis
| 0=XY, 1=XZ, 2=YZ
- BYTE
Orientation
| 0=Normal, 1=HFlip. 2=VFlip, 3=HFlip & VFlip
- UINT
Colour
| Specifies the foreground colour
- BYTE
SwitchBuffers
DrawCuboid
DrawCuboid
| Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
Z1
- BYTE
X2
- BYTE
Y2
- BYTE
Z2
- BYTE
DrawStyle
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- UINT
Colour
- BYTE
SwitchBuffers
DrawLine
DrawLine
| Draws a basic 3D line onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
Z1
- BYTE
X2
- BYTE
Y2
- BYTE
Z2
- UINT
Colour
- BYTE
SwitchBuffers
GetColour
GetColour
| Reads the colour value from a single pixel in the active buffer as a 16-bit value. Bits 0-4 = Red Bits 5-10 = Green Bits 11-15 = Blue
- BYTE
X
- BYTE
Y
- BYTE
Z
- UINT
| Sets up the data memory and draws the simulated LED cube on the panel.
PWMTimer
PWMTimer
| Interrupt driven macro to clock out the signals to the LEDs in the cube. To be called as part of a high frequency hardware timer interrupt or software loop to drive the cube hardware, Min Frequency = 60(Hz) * 8(Height) * 32(5-bitColourChannelValue)
ResetRotations
ResetRotations
| Resets the rotation count variables allowing for a new rotation to be started
RotateDisplay
RotateDisplay
| Shifts the contents of the display by the number of vertices specified
- INT
X
| Number of pixels to shift the display -7 to 7
- INT
Y
- INT
Z
- BYTE
SwitchBuffers
RotateShellXY
RotateShellXY
- BYTE
Direction
- BYTE
Shell
RotateShellXZ
RotateShellXZ
- BYTE
Direction
- BYTE
Shell
RotateShellYZ
RotateShellYZ
- BYTE
Direction
- BYTE
Shell
SetColour
SetColour
| Sets a pixel colour in the none active buffer using a 16-bit colour value Bits 0-4 = Red Bits 5-10 = Green Bits 11-15 = Blue
- BYTE
X
- BYTE
Y
- BYTE
Z
- UINT
Colour
| 16-bit Colour Value (MSB B5, G6, R5 LSB)
ShiftDisplay
ShiftDisplay
- INT
X
- INT
Y
- INT
Z
- BYTE
DataMode
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
- BYTE
SwitchBuffers
SwitchBuffers
SwitchBuffers
| Switches the current display buffer to the updated buffer to allow for seamless updates when undergoing heavy calcaulations.
- BYTE
WaitForSwitch
| 0=DoNotWait, 1=Waits for switch to occur
LEDs
Width (X)
| The number of LEDs wide
Depth (Y)
| The number of LEDs deep
Height (Z)
| The number of LEDs tall
LED Count
| Number of LEDs required by the component
LED Type
Common Type
Wiring Order
| Specifies the order of the wiring of the LEDs from lowest bit to highest
Driver Pre Delay
| Number of micro seconds to wait between switching off the driver and clocking out the new signals. Used to remove any ghosting effects visible on the display due to slow driver switch off times.
Driver Post Delay
Clock Pin
Data Port
Enable Port
LED Size
| Size of each LED on the panel
Spacing
| Number of units of spacing between each LED
Transparent
| If set to yes then a LED which is completely switched off will be set to transparent, If set to no then the LED will be shown as black.
Toggle Pins
| Determines if the pins are toggled as part of the PWMTimer macro during simulation. During simulation you probably don't want the pins toggling as it will slow down simulation. The only exception may be if you want to see the signals in the scope window. Does not effect the compiled embedded code.
