Component: RGB LED WS2801 (LEDs)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
RGB LED WS2801 component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
Please click here to download the component source project: FC_Comp_Source_temp/LED_WS2801.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_WS2801.fcfx
1D Configuration
In the 1D configuration each LED simply follows on from the last in a chain.
2D Configuration
In the 2D configuration each LED follows on from the last in a chain which travels back and forth through the columns a row at a time.
3D Configuration
In the 3D configuration each layer follows the 2D configuration with each layer then following on by mirroring the layer below. First layer connections are shown in Red and second layer connections are shown in Blue.
3V3 Microcontrollers
Note you may have to voltage shift the micro controller control pins to meet the 0.8 * VDD minimum requirement. E.g. if VDD is 5V then the input voltage needs to be at least 4V.
A simple buffer IC could be used to do the voltage shifting.
RGB Mood Light
A simple example using three potentiometers to set the individual Red, Green and Blue channels of the LED colour. FC6 Icon.png MoodLight MoodLight.jpg
Animated Light
A simple example which picks a random colour assigns it to the first LED, then shifts and repeats. FC6 Icon.png AnimatedLightStrip AnimLight.jpg
Animated Light Cascade
A simple example which picks a random colour assigns it to the first LED, then shifts and repeats. FC6 Icon.png AnimatedLightCascade AnimLight2.jpg
DrawCuboid3D
Fc9-comp-macro.png DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
Fc9-u8-icon.png - BYTE X1
Fc9-u8-icon.png - BYTE Y1
Fc9-u8-icon.png - BYTE Z1
Fc9-u8-icon.png - BYTE X2
Fc9-u8-icon.png - BYTE Y2
Fc9-u8-icon.png - BYTE Z2
Fc9-u8-icon.png - BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
Fc9-u8-icon.png - BYTE R
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
DrawLine2D
Fc9-comp-macro.png DrawLine2D
Draws a line on a 2D array of LEDs
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawLine3D
Fc9-comp-macro.png DrawLine3D
Draws a line on a 3D array of LEDs
Fc9-u16-icon.png - UINT Z1
Fc9-u16-icon.png - UINT Z2
DrawRectangle2D
Fc9-comp-macro.png DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
GetLEDColour
Fc9-comp-macro.png GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
Fc9-u16-icon.png - UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
Fc9-u8-icon.png - BYTE ColIdx
0 = R, 1 = G, 2 = B
GetLEDIndex2D
Fc9-comp-macro.png GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
LED Column to change the colour / Range: 0 to (LED Column - 1)
LED Row to change the colour / Range: 0 to (LED Row - 1)
GetLEDIndex3D
Fc9-comp-macro.png GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Fc9-comp-macro.png Initialise
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the WS2801 ICs in the chain.
Refresh
Fc9-comp-macro.png Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
SetAllLEDColour
Fc9-comp-macro.png SetAllLEDColour
Sets the colour of all the LEDs in RAM
SetBrightness
Fc9-comp-macro.png SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
Fc9-f32-icon.png - FLOAT Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
SetBrightnessByte
Fc9-comp-macro.png SetBrightnessByte
Fc9-u8-icon.png - BYTE Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
SetLEDColour
Fc9-comp-macro.png SetLEDColour
ShiftLEDs1D
Fc9-comp-macro.png ShiftLEDs1D
Shifts the LED colours in 1D and wraps
Fc9-u8-icon.png - BYTE Direction
0 = Forwards, 1 = Backwards
Fc9-u8-icon.png - BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
ShiftLEDs2D
Fc9-comp-macro.png ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
Fc9-s16-icon.png - INT X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
Fc9-s16-icon.png - INT Y
ShiftLEDs3D
Fc9-comp-macro.png ShiftLEDs3D
Fc9-s16-icon.png - INT Z
Fc9-conn-icon.png LED Properties
Fc9-type-16-icon.png LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
Fc9-type-21-icon.png LED Count
Total number of LEDs in the design
Fc9-type-21-icon.png LED Columns
Number of horizontal LEDs - X axis
Fc9-type-15-icon.png Column Spacing
X Spacing Between LEDs on the Panel
Fc9-type-21-icon.png LED Rows
Number of vertical LEDs - Y axis
Fc9-type-15-icon.png Row Spacing
Y Spacing Between LEDs on the Panel
Fc9-type-21-icon.png LED Layers
Number of LED layers - Z axis
Fc9-type-15-icon.png Layer Spacing
Z Spacing Between LEDs on the Panel
Fc9-type-7-icon.png Flip X
Flips the X axis if the LEDs are wired from the right hand side of the display.
Fc9-type-7-icon.png Flip Y
Flips the Y axis if the LEDs are wired from the bottom side of the display.
Fc9-type-7-icon.png Flip Z
Flips the Z axis if the LEDs are wired from the upper most side of the display.
Fc9-type-16-icon.png Arrangement
LEDs will likely be arranged in one of two ways. Parallel = Each row of LEDs run from left to right - easier to address but harder to wire. Alternating = Each row of LEDs runs in an alternating direction - harder to address but easier to wire.
Fc9-type-16-icon.png Output Mode
Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Fc9-conn-icon.png Connection Properties
Fc9-type-5-icon.png Data Pin
LED Data Pin - Connected to the Data In pin of the first WS8201 IC.
Fc9-type-5-icon.png Clock Pin
LED Clock Pin - Connected to the Clock In pin of the first WS8201 IC.
Fc9-type-16-icon.png API
