Component: LIN Slave (Comms)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Comms
LIN Slave component
Low level routines for controlling the LIN bus (1.3 / 2.0) slave interface.
Please click here to download the component source project: FC_Comp_Source_temp/LinSlave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LinSlave.fcfx
GetState
Fc9-comp-macro.png GetState
Returns the state of the device
Initialize
Fc9-comp-macro.png Initialize
Initialises the device
ListenForMessages
Fc9-comp-macro.png ListenForMessages
Listens for messages with Timeout and returns the state
Fc9-u8-icon.png - BYTE Timeout
Fc9-u8-icon.png - BYTE ChecksumType
0=Classic, 1=Enhanced
PowerDown
Fc9-comp-macro.png PowerDown
Power Down the device
ReadAddress
Fc9-comp-macro.png ReadAddress
Returns the Identifier read
ReadData
Fc9-comp-macro.png ReadData
Returns the message data byte
Fc9-u8-icon.png - BYTE Message
Message to be read
Fc9-u8-icon.png - BYTE Index
Index of data byte to be returned
ReadDataCount
Fc9-comp-macro.png ReadDataCount
Return the data count size for Message
SetData
Fc9-comp-macro.png SetData
Set the Message data to be automatically sent as part of the ListenForMessages macro.
Message to assign data for Range: 1-8
Fc9-u8-icon.png - BYTE Data1
Data byte value
Fc9-u8-icon.png - BYTE Data2
Data byte value
Fc9-u8-icon.png - BYTE Data3
Data byte value
Fc9-u8-icon.png - BYTE Data4
Data byte value
Fc9-u8-icon.png - BYTE Data5
Data byte value
Fc9-u8-icon.png - BYTE Data6
Data byte value
Fc9-u8-icon.png - BYTE Data7
Data byte value
Fc9-u8-icon.png - BYTE Data8
Data byte value
WakeUp
Fc9-comp-macro.png WakeUp
Wake Up the device
Fc9-type-5-icon.png TX pin
LIN bus data transmit pin
Fc9-type-5-icon.png RX pin
LIN bus data receive pin
Fc9-type-5-icon.png CS pin
LIN bus chip select pin
Fc9-type-5-icon.png FAULT pin
LIN bus fault detection pin
Fc9-type-5-icon.png VREG pin
LIN bus voltage regulation pin
Fc9-type-16-icon.png MESSAGES
Number of messages the firmware is designed to listen for
Fc9-conn-icon.png MESSAGE1
Fc9-type-14-icon.png ID
Message identifier to listen for
Fc9-type-16-icon.png BYTES
Number of bytes to expent in the packet
Fc9-type-16-icon.png TX_RX
Data direction for packet
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
A text label to aid identifying the component.
Fc9-conn-icon.png Timing Adjustments
Fc9-type-21-icon.png Timer Adjust TX
Fc9-type-21-icon.png Timer Adjust RX
