Component: MIAC AllCode (MIAC: PC Peripheral)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Category MIAC: PC Peripheral
MIAC AllCode component
MIAC AllCode. dsPIC version of the MIAC loaded with the AllCode firmware. Usefull for SCADA, Control or Test applications. Allows you to control the MIAC using the programming language of choice. Compatible with simulation / Bluetooth / Wifi / RS232 and RS485
Please click here to download the component source project: FC_Comp_Source_temp/MIAC_AllCode_Firmware.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MIAC_AllCode_Firmware.fcfx
Bluetooth based examples.
MIAC AllCode Bluetooth
WIFI based examples.
MIAC AllCode WIFI
USB Driver
USB Serial Driver
CardCreate
CardCreate
Attempts to create a specific file on the card. Returns 0 for success, 255 for no card or error.
- STRING Filename
CardDelete
CardDelete
Attempts to delete a specific file on the card. Returns 0 for success, 255 for no card or error.
- STRING Filename
CardInserted
CardInserted
Checks to see if a card is present. Returns 0 for no card or 1 for card detected
CardOpen
CardOpen
Attempts to open a specific file from the card. Returns 0 for file found and opened, 239 for file not found and 255 for no card.
- STRING Filename
CardReadByte
CardReadByte
Reads a byte from the open file.
CardWriteByte
CardWriteByte
Appends a byte to the end of the open file. Returns 0 for success.
- BYTE data
CommsBaud
CommsBaud
Sets the Baud rate of the alt communications channel
- BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
CommsRead
CommsRead
Reads a byte from the alt communications channel
- BYTE Timeout
Range: 0-255 : 0 = Don't wait / 1-255 = ms
CommsWrite
CommsWrite
Writes a byte to the alt communications channel
- BYTE Data
Range: 0-255
GetAPIVersion
GetAPIVersion
Gets the API version of the Robot ARM Firmware
LCDBacklight
LCDBacklight
Controls the brightness of the LCD backlight.
- BYTE Brightness
Range: 0-100
LCDBitmap
LCDBitmap
Draws a bitmap file from the SD card onto the MIAC display
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- STRING Filename
Range: 0-1
LCDClear
LCDClear
Clears the MIAC display
LCDCursor
LCDCursor
Sets the cursor position for the MIAC display
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-4
LCDLine
LCDLine
Draws a single pixel width line on the MIAC display
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
LCDNumber
LCDNumber
Prints a number to the MIAC display starting from the current cursor position.
- INT Value
Range: -32678 - 32767
LCDOptions
LCDOptions
Controls some of the LCD options
- BYTE Foreground
Range: 0-1
- BYTE Background
Range: 0-1
- BYTE Transparent
Range: 0-1
LCDPixel
LCDPixel
Controls a single pixel on the MIAC display
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- BYTE State
Range: 0-1
LCDPrint
LCDPrint
Prints a string to the MIAC display starting from the current cursor position.
- STRING data
Range: 0-21
LCDRect
LCDRect
Draws a single pixel rectangle on the MIAC display
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
LCDVerbose
LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
PWMConfig
PWMConfig
Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
- BYTE Channel
Range 0-1
- UINT Period
Range: 0-65535
- BYTE Scaler
Range: 0-3
PWMDuty
PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
- BYTE Channel
Range 0-5
- UINT Duty
PWMEnable
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
ReadAnalogInput
ReadAnalogInput
Reads a single digital input.
- BYTE Channel
ReadDigitalInput
ReadDigitalInput
- BYTE Channel
ReadInputs
ReadInputs
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7
ReadKey
ReadKey
Reads a keypress from the keypad.
ReadRTC
ReadRTC
Reads a value from the real time clock module. Used for getting the time or date.
- BYTE Unit
0=Second 1=Minute 2=Hour 3=Day 4=Month 5=Year
WriteRTC
WriteRTC
Writes a value to the real time clock module. Used for setting the time or date.
- BYTE Unit
- BYTE Value
WriteRelay
WriteRelay
Allows a single relay to be switched on or off.
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
WriteRelays
WriteRelays
Allows all relays to be switched on or off in a single command.
- BYTE Value
Range: 0-15 or 0b0000 to 0b1111
WriteTran
WriteTran
Allows a single transistor output to be switched on or off.
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
WriteTrans
WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
- BYTE Value
Operating Mode
Mode
Configures how the simulation component functions, does it simply simulate or does it control real hardware.
API Connection Type
API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network
AutoDetect Port
Baud
